timing belt questionpwssyz 04-23-2005, 11:16 AM after getting the #1 cylinder on TDC on the compression stroke on a 95 neon,what position should the valves be in on the cam??thanks in advance for any help stikine2 05-06-2005, 03:23 AM Closed! TEXSRT4 05-08-2005, 02:08 AM at TDC valves should be both closed. remove the spark plug, and have someone turn the crank bolt. use a flashlight and look into the hole. that should get you close, then look down at the crank sprocket, there will be 2 triangles. one will be immedaitly above the sprocket pointing down, and on the sprocket there will be a triangle. line up the 2 points of the triangle and you will be set. ScrafFD 05-09-2005, 07:38 PM In addition to the flashlight, I use a long straw, or more than one if you are checking a neon....This way you know if the piston is moving up or down. rksnc 05-11-2005, 03:16 PM When putting on timing belt if single over head cam the timing mark on cam gear goes up and crank is also up. There are alignment marks on the gear and the block and head to align marks. On a dual over head the cam gears has marks that will point to each other. There is a alignment mark on crank gear to align with mark on block. These mark are a must if they are not right it will be off. If marks are in right place the valves will be too. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
