loses mph's at high rpm
klynn
04-21-2005, 10:13 PM
I purchase a 96 dodge ram 1500 with the 5.9L magnum engine with approx 158000 miles about a month ago. I had the transmission flushed and inspected and was told it was in good shape and should have it flashed. I took it to a dealership and had it flashed. While at the dealership I had them look to see why my check engine light was on and they told me it was the oxygen sensor and replaced it. They also changed the sparkplugs, I had told them that the truck seemed be bogg down if I would try to kick it down to pass anybody, They thought that would take care of the problems. Every once and a while when the engine is idling I hear a rattling noise close to the cataystic convertor. Do you think that could be causing the lack of power? also when I kick it down the rpms while kick up to about 4100 rpm's and I will lose mph speed until I let off the gas and bring down the rpms to below 3100 rpms and then my mph's will increase.
1thunder
04-22-2005, 05:23 AM
sounds like your catalityc converter is plugging up tap on the converter with a rubber hammer to see if you can make it rattle
fredjacksonsan
04-22-2005, 10:42 AM
Yup, a common occurrence on the 96, time for new cats.
klynn
04-22-2005, 03:23 PM
I have an appointment to have it changed out tomorrow, I will let you guy's know what it is like after that. Thanks for the response. :) :)
fredjacksonsan
04-24-2005, 10:41 AM
And.....the answer is......?
1thunder
04-24-2005, 10:49 AM
YES it was the converter !!!! {maybe} hee hee !!!
klynn
04-24-2005, 10:01 PM
Yes it was the converter, When I was there I also had him put on a dual exhaust system. The truck has plenty of power now. When I got home I just had to test it out by hooking up our camper trailer (34'). It was like being in heaven and on earth at the same time. It also made a hugh difference on the shifting of the transmission. Thank alot guy's things are now great. :icesangel
fredjacksonsan
04-25-2005, 07:34 AM
Sweet....
BleedDodge
04-25-2005, 10:23 AM
Did you have to pay for new converters or were they warrantied? Did you even use new converters?
klynn
04-25-2005, 11:24 AM
The Converter Was Not Warrantied Because It Was The Original And The Pick-up Has About 148,000 Miles On It. But The Good Side Of Everything Is I Now Have Power And Better Gas Milage. YES I DID PUT ON A NEW CONVERTER BECAUSE OF THE 2 -O2 SENSORS
Sapper69
04-26-2005, 03:47 PM
odd i think the noise it the cat. mine made the noise then went out clogged on the way to work . not good at all
Dodgeintheblood
04-29-2005, 04:50 PM
I know a way to take the cat out and not trip any codes... basicaly the second O2 sensor looks for heat and more O2 then the first one. So i just welded a braket to srew the second O2 sensor to the out side of the exauhst pipe, it is like a little box for the sensor. Put 4000 miles on and have yet to trip a code, also improved my mpg alittle.
