chnged valve cover and now wont start
benw
04-21-2005, 10:01 AM
Got a '92 laser that had a cracked valve cover and was leaking oil. It sat for a while untill I got a new one but now it wont start. Does crank and I tried starting fluid and got nothing. Any ideas?
91 Eclipse
04-21-2005, 04:16 PM
the seal around the vavle cover might be shot. that happened to me when i did my engine swap.
1stGenRocks
04-21-2005, 04:37 PM
did you put the plug wires back in the right order? double check everything that you disconnected to do the valve cover
gthompson97
04-25-2005, 11:19 PM
the valve cover gasket has nothing to do with the car starting....the car will start with the valve cover off...check everything you took off and make sure you put it back on right
