Damnit not again
rendertrust
04-20-2005, 01:10 PM
ok well my car didnt start this morning again, last time it was because the PS fluid leaked onto the alternator... this time whats happening is i just hear spinning .... thats the starter right, i heard that you could just adjust the started with a screwdriver to fix it
k3smostwanted
04-20-2005, 04:46 PM
also try hitting it with a hammer, this sometimes on binds something. it sounds like the gear is getting jammed on the pressure plate and binding so the motor is winding out. it could also mean your starter is screwed but try that and i have heard soemthing about a screwdriver to but i dont know...
probehtr300
04-20-2005, 09:38 PM
are u drivig it with a blow headgasket ?????
-The Stig-
04-20-2005, 10:02 PM
Sounds like the starter solenoid is going out. I'd just change the starter.
k3smostwanted
04-20-2005, 11:57 PM
yeah thats probably the easiest...
but on another note...please tell me you have that headgasket replaced!!!
ExTrEmEDrIfT
04-21-2005, 01:52 AM
yah cause if you havent changed your head gasket the started solenoid is the least of your problems
Bdetore
04-21-2005, 01:26 PM
It's possible that all the spark plugs have been removed. If their missing then the cylinder isn't sealed, and there's no compression the engine will just roll easy, and with no spark nothing can burn.
But,...Chances are your starter needs to be replaced.
ExTrEmEDrIfT
04-21-2005, 04:15 PM
haha that would be some funny shyt but he stated the car was already running before and tahst pretty noticeable
Bdetore
04-21-2005, 11:31 PM
Soley in jest my friend. I know better.
