Headlight Motor Gear
Google
Web AF
cornerofdivision
04-19-2005, 08:18 PM
I'm sure most firebird owners have had the gear of their headlight motor become stipped. I was wondering if it would be better to buy a replacement gear, like the metal ones found on ebay. Or to buy a whole new or used motor? I know replacing the gear would be cheaper, has anyone here done it and how tough was it?
FormulaLT1
04-19-2005, 09:02 PM
I changed mine to the bronze one's and its not too bad. I figured it was better to do it right once than having to do it over like 3 times in a couple years. The bronze ebay gears come with step by step instructions and is not that hard even for a novice and it will save you the trouble of having to worry about doing it again down th road. Good Luck
John
Mr. Luos
04-19-2005, 09:28 PM
http://www.bfranker.badz28.com/headlightfix/index.htm
I haven't had to replace mine yet. I will get the brass gears when I do though.
cooltc2004
04-20-2005, 02:09 PM
Any of those work on a 3rd gen?
99onI95
04-25-2005, 09:23 PM
Like formula I replaced one of my gears with bronze. Also check your rubber stops on the headlights worn stops will cause your light to bounce even after gear replacement.
oxiderush
04-26-2005, 09:14 AM
the moron i just bought my car from installed a 3 in cowl hood that didn't line it up right, and overlapped the headlight doors. That's probibally why the're burnt out on my car
Google
Web AF
