Manual Transmission LubricantRacincc85 04-19-2005, 12:38 PM I've got a 1991 camry with the 3S-FE 4 cyl DOHC engine and manual transmission. I just purchased the car and it needs a transmission fluid change. I purchased the Haynes manual for it, and it recommends dextron 3 ATF for 4 cylinder models equipped with a manual transmission, but 75W-90 gear lube for V6 models equipped with a manual transmission. Something doesn't seem right to be about that. I would think the two transmissions would be the same internally, so why the different recommendation? Should I use the atf of go with the 75w-90 gear lube? Brian R. 04-19-2005, 10:34 PM Use gear lube From the AMSOIL website: http://www.amsoil.com/scripts/runisa.dll?amsoiloaf:index 1991 TOYOTA CAMRY 2.0L 4-cyl VIN Code G 3S-FE FILTERS Oil Filter......SDF10 Oil Vapor Filter......N/R Air Filter......TS76 Fuel Filter......GF288 Fuel Vapor Filter......N/R PCV Valve......N/R Trans......TF117 BOSCH SPARK PLUGS LE ALL TRAC Wire......B09980[1] Plug......B4418[1] LE Wire......B09980[1] Plug......B4418[1] DLX ALL TRAC Wire......B09980[1] Plug......B4418[1] DLX Wire......B09980[1] Plug......B4418[1] ALL TRAC Wire......B09980[1] Plug......B4418[1] All other Submodels Wire......B09980[1] Plug......B4418[1] 1. Cap/Wire design set Cap/Wire design set BOSCH WIPER BLADES Driver side......B40919 Passenger side......B40917 Rear window......B40915 CHASSIS LUBRICATION 0 Fittings, 0 Plugs LUBRICANTS & FLUIDS Engine Oil Grade 1......API* Synthetic 5W-40 European Engine Oil SAE 10W-40 Synthetic High Performance Motor Oil SAE 10W-40 XL-7500 Synthetic Motor Oil Above 0°F......10W-40 Manual Transmission,4WD.....GL-4 Above -18°C......90 Gear Oil, API Service GL-4 Manual Transmission,4WD.....GL-5 All temps......75W-90, 80W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Manual Transmission,4WD.....GL-5 Above -18°C......90 Gear Oil, API Service GL-5 Manual Transmission,4WD.....GL-4 Below -18°C......80W Gear Oil, API Service GL-4 Manual Transmission,2WD from 4/90.....GL-5 All temps......75W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Manual Transmission,2WD from 4/90.....GL-4 All temps......75W-90 Gear Oil, API Service GL-4 Manual Transmission,4WD.....GL-4 All temps......75W-90, 80W-90 SAE 80W-90 Synthetic Gear Lube SAE 80W-90 Synthetic Lower Unit Gear Lube Manual Transmission,4WD.....GL-5 Below -18°C......80W Gear Oil, API Service GL-5 Automatic Transmission,4WD.....TTA[1] Synthetic Automatic Transmission Fluid Automatic Transmission.....AF3 Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Differential, Front .....AF3[2] Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Differential, Rear .....GL-5 Above -18°C......90 SAE 80W-90 Synthetic Gear Lube Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Transfer Case,.....GL-5[3] Below -18°C......80W SAE 80W-90 Synthetic Gear Lube Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube [3] Above -18°C......90 SAE 80W-90 Synthetic Gear Lube Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube [3] 75W-90, 80W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube SAE 80W-90 Synthetic Gear Lube Fluids Power Steering Fluid.....AF3 Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Brake Fluid.....HB Hydraulic Brake Fluid, DOT-3 Clutch Fluid.....HB Hydraulic Brake Fluid, DOT-3 1. TTA is Type T ATF, Toyota part no. 08886-00405 2. Final drive for automatic transmission only. 3. Trc W/ automatic transmission only. CAPACITIES Engine, without filter..........3.9 quarts[1] Cooling System, Initial Fill..........6.9 quarts Automatic Transmission, 2WD Initial Fill..........2.5 quarts[2] Automatic Transmission, 4WD Initial Fill..........3.5 quarts[2] Automatic Transmission, Total Fill 4wd ..........7.4 quarts fwd ..........6.3 quarts Manual Transmission, 2WD..........5.5 pints[3] Manual Transmission, 4WD..........11.0 pints[4] Differential, Front..........3.4 pints[5] Differential, Rear..........2.3 pints[6] Transfer Case,..........1.5 pints 1. Capacity shown does not include filter. When replacing filter additional oil may be needed. After refill check oil level. 2. With ENG automatic transmission operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed. 3. Capacity includes final drive. 4. Capacity includes transfer case. 5. Final drive for automatic transmission only. 6. Rear diff is for 4wd models only. TORQUES Oil Drain Plug.....29 ft-lbs Oil Drain Plug.....18 ft-lbs Manual Transmission Fill Plug.....36 ft-lbs Drain Plug.....36 ft-lbs CAUTIONS TRANS/DIFF 4WD W/ MT: To drain front differential, transfer case and transmission, remove two drain plugs. One is located on the bottom of the case between the front axles, the other is located under the drivers side axle on the side of the case. TRANS/DIFF 4WD W/ AT: Transmission and front final drive share the same lubricant and drain/ fill together. Transfer case is a separate component. Drain transfer case through drain plug on case, fill through dipstick/ filler tube. SERVICE INTERVAL http://www.amsoil.com/lit/g1490.pdf jsinton 04-26-2005, 05:53 PM Wow, what a great answer BrianR! Everybody should print that out and tape it to the hood! Brian R. 04-27-2005, 09:10 AM Thank the guys who run the AMSOIL website. oakfloor 05-06-2005, 12:58 AM I've got a 1991 camry with the 3S-FE 4 cyl DOHC engine and manual transmission. I just purchased the car and it needs a transmission fluid change. I purchased the Haynes manual for it, and it recommends dextron 3 ATF for 4 cylinder models equipped with a manual transmission, but 75W-90 gear lube for V6 models equipped with a manual transmission. Something doesn't seem right to be about that. I would think the two transmissions would be the same internally, so why the different recommendation? Should I use the atf of go with the 75w-90 gear lube? Wait! Amsoil does not make a manual transmission oil, its a differential lube. dont use in tranny. please check your info. BTW redline makes a good tranny lube. Brian R. 05-06-2005, 07:01 PM Wait! Amsoil does not make a manual transmission oil, its a differential lube. dont use in tranny. please check your info. BTW redline makes a good tranny lube. Read the AMSOIL information about the recommended gear oils before you make that statement. Here's a quote from AMSOIL: http://www.amsoil.com/storefront/fgr.aspx Long Life 75W-90 Gear Lube Applications AMSOIL Long Life Synthetic Gear Lubes, in the correct viscosity grades, are recommended for all domestic and foreign applications such as over-the-road trucks, light, medium and heavyduty trucks, off-road equipment, commercial vehicles, motorhomes, autos, SUVs, emergency vehicles, busses, delivery/utility vehicles and tractors. Use AMSOIL Extended Drain Synthetic Gear oils in differentials, manual transmissions or other gear applications where one or more of the following standards are specified: API GL-5 & MT-1, MIL-PRF-2105E, Dana SHAES 234 (Formerly Eaton PS-037) for 250,000 miles, Dana SHAES 256 (Formerly Eaton PS-163) for 500,000 miles, Mack GO-J & GO-J+, Meritor 0-76N, and Navistar TMS 6816 plus hypoid gear oil specifications from all foreign and domestic manufacturers such as GM, Ford and Daimler Chrysler. Can also be used in rear axles where API Service GL-4 lubricant is recommended. Another recommended oil is: http://www.amsoil.com/storefront/svg.aspx with a similar recommendation. To me, that means they say they are appropriate for use in transmissions. So, unless they buy it and repackage it, they make it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
