85 toy pu engine swap no sparkjmorse 04-13-2005, 09:58 AM I just swapped the engine w/ weber from my 1983 to a 1985 PU. Now I'm not getting any spark. I do have power to the coil. ???? Furdog 04-13-2005, 02:22 PM I just swapped the engine w/ weber from my 1983 to a 1985 PU. Now I'm not getting any spark. I do have power to the coil. ???? Did you check to make sure you have spark to the plugs?? jmorse 04-14-2005, 11:33 AM of course. we are having coil problems cause I didn't pull the old coil from the 83 before it got junked. so I think we are having a resitance problem gar 04-15-2005, 05:33 PM of course. we are having coil problems cause I didn't pull the old coil from the 83 before it got junked. so I think we are having a resitance problem had sim problems w/ my 88 swap.pulled efi and dropped in 84 carb motor.had power to coil but no spark ,after racking my brain awhile i cleaned up all electrical connections, it worked!!!!i am pretty sure it was the ground on coil.the ciol body must be grounded to fenderwell.keep us posted.greg vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
