Help with Connector on firewall!megawayne 04-11-2005, 04:00 PM I have a red with blue stripe and a yellow wire on a connector hanging on the firewall. What exactly does that go to. It does not connect to anything. Thanks. jason-1995fbody 04-12-2005, 12:28 AM is it on the driver side and what year is it megawayne 04-12-2005, 09:32 AM 1994 driver side near coil megawayne 04-12-2005, 10:47 AM how do you use it to set timing? It isnt the 5 port jumper port. jason-1995fbody 04-12-2005, 10:55 AM yes it connecects to something it a fuel injector resisstor should be an aluminume box (small) with a heat sink on it megawayne 04-12-2005, 10:57 AM mine still has that next to the strut tower. This is left of the coil. jason-1995fbody 04-12-2005, 11:02 AM how do you use it to set timing? It isnt the 5 port jumper port. sorry yer right i deleted that post but not soon enough i guess it it is the fuel injector resisstor plug megawayne 04-12-2005, 11:04 AM does it have a use or need to be plugged to anything? jason-1995fbody 04-12-2005, 11:32 AM as far as i know it need to be pluged into the box that contain the resistor megawayne 04-12-2005, 11:35 AM here is my firewall. You can see what i mean. http://images5.theimagehosting.com/geo metro 001.jpg (http://www.theimagehosting.com) jason-1995fbody 04-12-2005, 11:44 AM you are refering to the yellow connector on the far right megawayne 04-12-2005, 11:45 AM where the two clips are holding the wiring harness to firewall left of the coil, it is in between them. you can barely see it. It is a small two wire pigtail. jason-1995fbody 04-12-2005, 11:53 AM ok i see it dose yer car have a one or 3 wire o2 sensor megawayne 04-12-2005, 11:55 AM 4 wire jason-1995fbody 04-12-2005, 12:00 PM ok thats why min dosent have it tou have the upgraded emissions and i have standardhttp://files.automotiveforums.com/gallery/watermark.php?file=/500/280513metro_coil-med.JPG jason-1995fbody 04-12-2005, 12:01 PM ok thats why min dosent have it tou have the upgraded emissions and i have standardhttp://files.automotiveforums.com/gallery/watermark.php?file=/500/280513metro_coil-med.JPG i think it is nothing to worry about but ill look give me a minute and ill let you know jason-1995fbody 04-12-2005, 12:20 PM cant find it on all data but there are a shit load of splices so i could look for ever and still not find any thing i would say if it isnt a problem dont worry about it lots of cars have lots of diferent open conectors for opional accesories and test ports and such so if you dont have a problem i would just leave it alone vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
