Wiring diagram for 1996 JGC infinity amp please!!
dkpotter
04-11-2005, 01:47 PM
Dear All,
I am in process of bypassing the infinity amp (blown) in my 1996 JGC ltd
As there are more wires going into the input then there are in the output, I would be grateful to anyone that can give me an idea of which wire is which..WJJEEP.com is helpful but only gives 1999 JGC and on..
Many thanks
Dave
dksob81
04-11-2005, 03:07 PM
ok here it is.
Left body Harness Conector (14 Pin):
From LEFT to RIGHT. TOP to BOTTOM
#1 - Left Rear Speaker (+)
#2 - Battery Feed
#3 - Left Front Speaker (+)
#4 - Not Used
#5 - Left Rear From Radio (+)
#6 - Left Front from radio (+)
#7 - Left Rear Speaker (-)
#8 - Battery Feed
#9 - Left Front speaker (-)
#10 - Ground
#11 - Ground
#12 - Not Used
#13 - Left Rear from radio (-)
#14 - Left Front from radio (-)
Right Body Harness (10 Pin):
From LEFT to RIGHT, TOP to BOTTOM.
#1 - Right front speaker (+)
#2 - Right front speaker (-)
#3 - Right rear speaker (+)
#4 - Right front from radio (+)
#5 - Right rear from radio (-)
#6 - Right rear from radio (+)
#7 - Not Used
#8 - Radio switched signal feed
#9 - Right rear speaker (-)
#10 - Right front from radio (-)
dkpotter
04-11-2005, 03:15 PM
Many thanks for that...you have saved many hours of work !!!
All the best from england
Dave
ok here it is.
#2 - Battery Feed
#4 - Not Used
#8 - Battery Feed
#10 - Ground
#11 - Ground
#12 - Not Used
#7 - Not Used
dksob81
04-11-2005, 09:28 PM
Your Welcome
thats what we're here for
carwashcat
05-29-2005, 09:21 PM
do you know the color codes for the radio (my was stolen and the wire plugs cut) Plese help me!
dksob81
05-30-2005, 12:50 PM
Right Rear Soeaker (-) - Dark Blue/Pink
Left Rear Speaker (-) - Brown/Light Blue
Right Front Speaker (+) - Violet/Yellow
Left Front Speaker (+) - Orange
Right Rear Speaker (+) - Dark Blue/White
Left Rear Speaker (+) - Brown/Yellow
Amp ON-OFF Signal/Aantenna Up Signal - Dark Green/Red
Battery (memory) - Red/White
Accessory (switched B+) - Red/Grey
Dimmer (panel, lamp, variable) - Orange
Marker (head, park lamp) - Dark Blue/Red
Right Front Speaker (-) - Dark Blue
Left Front Speaker (-) - Brown/Red
endlessmyk
06-04-2005, 11:54 PM
I DON'T HAVE ENOUGH WIRES!!!
I'm trying to hook up my AIWA CD player, my stereo was stolen, cut wires, so I'm trying to go by the above guide. I've got a 97 JGC Laredo, and coming from my headunit I have:
Front Left (+) White
Front Left (-) White/Black
Rear Left (+)Green
Rear Left (-)Green/Black
Front Right (+)Gray
Front Right (-)Gray/Black
Rear Right (+)Violet
Rear Right (-)Violet/Black
Red - To Power (ACC)
Yellow - To Battery Direct (Back UP) Fuse 15A
Black - Ground
Blue - To Relay Control
Now, my blue wire is hooked up to a little fuse right now, and the way I hooked it up, everything came on, but there was no sound and I had a couple extra wires... new to the Jeep world, please help!!!
g1smith
08-12-2005, 02:03 PM
The back right speaker on my '99 JGC usually works great for a little while before it starts distorting, and sounding like a ripped speaker. (I've taken it out and swapped it with the left speaker without any improvement).
Am I looking at a bad or blown Infinity AMP?
What are my options in fixing this?
Not ...... Buy a replacement from the dealer.
Maybe .. Will a used one work or is there some security code that must be programed into them like the Mitsubishieeeeseses's?
Idea ..... Put in an after marked AMP following the wiring diagrams from this post?
dksob81
08-12-2005, 02:46 PM
From your description it sound slike the amp might be overheating. I am not sure about the code thing, Your WJ might require it.
