View Full Version : Help installing electric fan!
AWDSR20
04-11-2005, 01:09 AM
Hi wasap everyone. My clutch fan went out and (its loose, and it shakes allot) I going to get a dual fan from the junkyard and install them in. I just don’t know how to hook the fan to the thermostat swish. I could install it to the battery and keep it running via a switch in the cockpit, but I rather have it controlled via the thermostat. I don’t know how to do that dough.
How can I install electric fan on a clutch fan motor and have it running appropriately with the thermostat?
tnx
AWDSR20
04-11-2005, 01:10 AM
BTW i have the SR20det
nissanfanatic
04-11-2005, 01:16 AM
Use a temp activated switch. www.summitracing.com sells them. Will require a little work.
AWDSR20
http://www.240sx.org/links/installs/first_gen_electric_fan_install.htm
i going to use this as a guide... i'll let you know if it going to work.
slideways...
04-11-2005, 12:02 PM
buy the lower radiator hose assembly for a 89-90 sohc 240sx
it comes with a temp sensor for the stock A/C fan but you can wire it to a relay then to the electric fans to control them
AWDSR20
04-12-2005, 04:53 PM
fixed the stock cluch fan.... it wasnt that bad, so no electric fan for right now...
NiSmO_zt
04-14-2005, 05:30 PM
when you do get an electric fan, just wire it to a toggle switch on one of your dash blanks, its super easy, and you can turn it off when you race, for more power! lol, it makes a difference on my n/a ka, but you probably wouldnt notice a difference on the high power sr.
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
