1998 s10 not starting
Google
Web AF
fredbear
04-08-2005, 09:08 PM
i am puzzled! i have a 1998 s10 that will not start. i've replaced coil packs,ign. mod. and still not starting.it will crank over but will fire.i have spark and fuel. i know someone on here might be able to help me.
BlazerLT
04-09-2005, 04:13 AM
check fuel pressure
fredbear
04-10-2005, 08:23 PM
fuel pressure ok,could this be a timing issue,or crank sensor maybe
BlazerLT
04-10-2005, 09:21 PM
What is the fuel pressure reading?
andy001
01-08-2008, 11:48 AM
I'm having the same issue on a 1998 s-10. New wires, cap, rotor, coil, plugs....what else could it be??????
16th hippy
01-08-2008, 09:24 PM
@Fred: assuming you have the 2.2I4 since you replaced coil packs. you said "will crank over, but will fire"??? meaning it will spit and sputter, or not catch at all? as Blazer asked, what was the actual reading for fuel pressure? how was the truck running before? did it make a pop and quit? was fuel filter changed? i have seen where clogged filter will still give good pressure reading, but not enough fuel volume gets to engine.
@Andy: since you replaced cap and rotor, assumnig you have the 4.3V6. same kinds of questions. getting fuel? getting spark? how was it running before, any spits and sputters while cranking?
j cAT
01-08-2008, 09:41 PM
spray starting fluid into intake 2seconds worth no more , if it starts and then rapidly dies you have fuel problem this technic can be used on most gas engines as a quick way to determine if engine is gas starved.......
ZL1power69
01-11-2008, 02:08 AM
thread is almost 3 years old. please refrain from posting in old threads :nono:
Google
Web AF
