Need help with my Yugo 45A
Google
Web AF
Jim Bono
04-08-2005, 12:30 PM
Hi everyone,
I have a Yugo 45A and the engine often chokes (feels like a short gap while running). I changed plugs, leads, etc. but didn't seem to do the job. So I took it to a mechanic (six months ago) and after that it seemed to go much better. He said he tuned the carburetor.
But after driving several hundred miles it started choking again.
So does anyone know how I can tune a Yugo 45A carburetor since mechanics in England are bloody expensive and can't afford to take it there once more??
If it helps, it seems to choke when I press down the accelerator NOT when running with no gear, maybe it is the air rather than the fuel mixture that needs adjustment...??
I would really appreciate some tips !
cheers,
J
2strokebloke
04-08-2005, 11:27 PM
Perhaps the main jet is too large? Could also be leaking vacuum lines, or gaskets.
Jim Bono
04-09-2005, 05:06 AM
do you have any web site in mind that offers technical info on how to go about checking these out ??
Jim Bono
04-11-2005, 11:29 AM
I managed to fix it. It was actually a pipe connected to the oil tank with the air filter that was blocked up by oil residues and in result was blocking all incoming air into the engine, making it starve for air and have frequent gaps in engine power.
anyway god knows if anyone who actually knows about Yugos, understood anything from my description...! :-)
just wanted to let people who helped know...
cheers 2stroke.
D
DIZNA
01-31-2009, 09:41 PM
Hi! Help is here, I live in Macedonia here have a lot of spares for YUGO used but good carburetor cost 10-20 euro. marko_850@hotmail.com
DIZNA
01-31-2009, 09:45 PM
Yes maybe "IBERLAUF" (the pipe who connected from oil tank to air filter) is problem! The smoke who come from oil burning (broken piston rings) run into carburetor and car not work properly. Just remove this pipe and everything will be OK
soony
07-09-2009, 04:06 AM
I had a Yugo 45 A a long time ago. It was the only car i could fix myself. I always had a wire and pliers with me, and I could repaired it. Everything but the engine it self of course. Miss that car, noways I have to pay a lot for the mechanics ;)
Google
Web AF
