radiator fanIvan R 04-07-2005, 11:12 PM I have a 89 GTU with a 2.8 it has a single radiator fan. my -problem is that no matter what temp the engine gets to the fan does not turn on unless I use A/C or what not. My uncle said that he had changed the switch { witch one i dont know? } if anyone has any idea what may cause this please reply. please give details as to where i can find the switch(s). Thanks. anomaly_va_1976 01-25-2008, 11:53 PM I had an 86 Century - 2.8L carb'd and the fan would not come on, computer had a bad chip.... also could be a bad relay, or bad sending unit... cars with gauges have two senders, one is a switch, other is a sensor. Also make sure the fan motor is not bad-- try jumping the fan motor out with battery voltage.... Also, is the fan properly connected and grounded? '97ventureowner 01-26-2008, 12:13 AM This thread is nearly 3 years old! Please check the dates before you post. Closed. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
