Starting Issue On S-10 Extreme - HELP !!!!!Alnico 04-07-2005, 05:20 PM I have a 2000 Chevy Extreme. My Truck will not start randomly on occasion. When I turn the ignition I get dash lights, I hear the fuel pump turn on but I get no voltage to the starter. I verified I am getting 12V to the starter just fine. HERE IS WHERE IT GETS WEIRD.. When it will not start if I tap on the brake, it will start!!!!! It is more likley NOT to start when it's parked on a incline also.. WEIRD EH??? Sometimes I have to tap harder and longer then other times but it will start. I replaced the starter, same issue, I replaced the ignition saftey switch, same issue. the ONLY thing in my thoughts it could be is the ignition switch but on several occasions when it wouldn't start I have beat the living hell out of the collum to see if it would kick, NADA. ANY IDEAS ??? I am thinking it's an electrical issue. Thanks, Allen Mance alnico@woh.rr.com kenyonja2007 04-07-2005, 06:04 PM Have you checked all the wires under the steering column for good connections, bare wires, etc.? The reason I say this is that maybe pushing the brakes will push the brake arm away from a bare wire that is touching it. When it is on an incline, the wire may touch the brake arm easier, allowing it not to start. Just a thought, but not likely as it seems you are somewhat mechanically inclined and have checked this yourself. OverBoardProject 04-07-2005, 08:42 PM Your poor stearing columb! my guess is the same as yours the ignition switch. beating on teh columb wouldn't likely affect the switch it's self good luck BlazerLT 04-09-2005, 04:27 AM Does the starter click at all when it won't start. Take a voltmeter out and check the voltage when running and when parked overnight. Sparsky 04-09-2005, 09:39 AM Mine does this... check your battery cables/connections. Mine was corroded causing it to arc and sometimes not start, yet all the gauges and fuel pump would work. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
