Camry electric wind. motorquincyguy 04-07-2005, 10:16 AM Hi ! Halfway through replacing a dead RF electric window motor on a 'thoroughly indestructable '90 Camry. But - I can't undo the Allen head screws holding the motor to the regulator. A 4MM hex is too small, a 5MM is too large. Is there a special tool for the little buggers? Also - do I have to remove the regulaor to change the motor? Thank you ahead of time Jim GSS123 04-08-2005, 03:53 PM would they be Torx head bolts by any chance??? quincyguy 04-10-2005, 02:41 PM would they be Torx head bolts by any chance??? Turns out they were combination head screws (flat & phillips) & thoroughly rusted in. Removed the regulator and then got them out , truly challenging. Plus - the problem wasn't the motor!! (Anger, stamps foot, shakes fist) Many thanks for the suggestion, though. That thought had crossed my aging mind. Thanks again Jim vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
