Brights switch...
Google
Web AF
TK95Beretta
04-06-2005, 09:49 PM
Does anyone know what exactly I have to buy if the switch for the brights does not work anymore? Also, is it easy to install? Works fine for the turn signals but the brights don't work.
jsgold
04-10-2005, 03:37 PM
Pretty sure your high-lo switch should be at the middle part of your steering column and is activated by a rod that is connected to the lever on your column. A lot of times it simply works loose and all you have to do is re adjust and re tighten. No a major pain to replace if you have to, but try this first. You should be able to access it under the dash. May have to remove a panel etc., but should be able to see it easily.
Omega_5
04-21-2005, 04:23 AM
three words about replacing the dimmer switch..... BITCH TO DO!!!!!
i got half way through trying to replace that thing, and i said f*** it... and stormed out of the garage all mad like....
i ended up just cutting a push button into the dash just below the headlight on-off switch.... so now my low beams are ALWAYS on when the lights are on, and my new switch turns on the highs only... that way i get dual headlights (like berettastuff.com has as a mod...lol) and i got rid of that stupid steering column dimmer....grrrr...lol
Google
Web AF
