Reversed battery terminals
Google
Web AF
V_rizla
04-06-2005, 04:39 PM
I accidentaly reversed my battery terminals and must have fried something truck won't start. The ecm B fuse was fried put a new fuse of same amp in and fried imedietly pulled the computer out doesn't look like it's fried don't know if you can tell by looking at it. What should I try next?
J-Ri
04-06-2005, 04:47 PM
You can't tell by looking at it. You should take it to a shop and have them check it out. If it won't communicate with a scan tool, it's shot.
J-Ri
04-06-2005, 04:53 PM
Also, what year is it? I'm parting out a 93-ish S-10 (should work for 84-94, according to an auction listing on e-bay), if you want the computer, I'll pull it out for you. The check engine light was on from the engine overheating, so you will either have to clear the code or live with the light being on
V_rizla
04-06-2005, 05:42 PM
88 s10 blazer I think it is the computer that is fried I pulled it out put new fuses in and the didn't fry, is there anything else I could have fried that would need to be replaced?
Drova
04-06-2005, 06:41 PM
I know same fuse in mine was blowing but was due to a wire grounding on teh chassie
OverBoardProject
04-06-2005, 11:43 PM
I know that it's from the Ford Escort forum, but this guy has the same prob.
It might give you some ideas
http://www.automotivehelper.com/topic389697.htm
OverBoardProject
04-06-2005, 11:45 PM
the 1 thing that I really like about top post batteries is the fact that 1 post is larger than the other making this mistake harder
dmbrisket 51
04-07-2005, 03:30 AM
^ the advantages to top post are enought that im doing a swap this summer, they are easyer to clean and have a better contact then side mount
V_rizla
04-07-2005, 07:26 PM
I talked to a shop forman at a chevy dealer he said that I could have fried a wire now its touching something that keeps blowing the fuse cant seem to see anything unless it's inside the wire harness think I need pro help unless some one can point me in the right direction
16th hippy
04-07-2005, 10:01 PM
right direction is simple.....get a FULL wiring diagram and start pulling wire till you find it....use a meter for continuity tests....or take it to a shop.
dugie6551
04-08-2005, 07:57 AM
Make sure the shop you take it to specializes in automotive electronics. There is a shop where I live that is called "UAE - Universial Automotive Electronics". I have had to use them a few times to fix the problems that I could not find. Look for a place like that or maybe even a custom stereo shop.
OverBoardProject
04-08-2005, 12:03 PM
I personally wouldn't take it to a stereo shop. They are great at installing new things, just not trained to search for problems
Google
Web AF
