Weathered plastic on upper rear sides?
Google
Web AF
tom3
04-05-2005, 01:59 PM
Notice on the upper rear sides of our 01 Blazer the plastic around the windows that wraps to the rear hatch window is getting rough and looking bad. Can this piece be taken off and replaced? Maybe painted in place would be better? Our Blazer sits in the garage most of the time (16K miles so far) and I'm surprised to see this already. Anyhow, any tips on how to make this look better?
BlazerLT
04-05-2005, 05:41 PM
yes, have you ever used a protectant on your interior?
You should do that.
It will bring it back.
I do my whole interior 3 times a year and on my 1995, the interior looks better than it came out of the factory.
Flashbac29
04-05-2005, 08:10 PM
I had the same problem with a 96 model 2door jimmy. You can buy the replacement plastics for this, but they cost between 500 - 1000 dollars per side. You can drill out the rivets and screw in the new ones. I attempted to sand down and paint mine.... it looked fair, but I had allowed mine to go for several years and the plastic was severly pitted... i think it's just the plastics response to sun damage.
BlazerLT
04-05-2005, 09:15 PM
oh, we are talking about the exterior pieces?
AlmostStock
04-05-2005, 11:28 PM
I like to use bumper black polish (made for black plastic) on these parts. It may bring it back somewhat but the best approach is to use it regularly before it gets bad.
tom3
04-06-2005, 10:34 AM
Thanks for the replies. Yep, exterior trim back there. Suppose paint is the best route. Seems like a pretty poor material for this trim as our Blazer sits in the garage most of the time and it stays clean most of the time.
rlith
04-06-2005, 04:40 PM
Yes, due to a day off and boredom I figured since my front end was just redone, I would clean up my weather beaten plastic.
We all know that the plastic shell stuff on our trucks oxidizes, gets weather beaten and wind burned, and after a while (in my case 10 years) it really looks like ass. Some people are happy with just slapping some armourall (crap) or a good silcone based coating on it before they go out or on the next sunny day. I've never been happy with that. I like my stuff to look like new even when there isn't some kind of detailing fluid on it. I've done this to my wife's car and it's come out well, just never got around to doing it to mine.
Note: This also will apply to general buffing for clear coats, but you really need a buffer. A buffer, not an orbital waxer. I reccomend the Mikita buffers as they can go as high as 1000 rpm and as low as 10 rpm. Be careful though, you can burn straight through your clear coat. ORBITAL BUFFER/WAXERS WILL NOT WORK FOR PROPER BUFFING.
On to the pics..
Here you can see what I use. EZ1 Cutting gel (Blue) and 3M Foam Finisher polish. This is what most autobody shops use, (at least around here). Now, understand, the CRAP you would buy at Autozone, pepboys, or any other chain store is general consumer ****. To get this stuff you need to go somewhere that supplies automotive paint. (Real paint, not rattle can crap). I am a big believer in if you're going to do something, do it right. Consumer based crap is NOT doing it right...
http://www.pghconsulting.net/detail/stuff.jpg
Start with putting a couple of quarter sized drops on the plastic.
http://www.pghconsulting.net/detail/plastic1.jpg
Next, using a SLIGHTLY damp cloth, rub in circular motions. You eventually will see the plastic shine up. Just keep on going and going and going. (about 5-8 minutes in constant motion)
Wipe off with a soft towel really well when done.
http://www.pghconsulting.net/detail/plastic2.jpg
If you have any nicks in the plastic, simply wet sand the nick down with 1500 grit (not anything less) sand paper. Go back and reapply the cutting gel.
Now, you will have some swirl marks and or light sand paper marks after you're done. (Depending on how bad your plastic was)... So now we move on to the final step.
Use a dime sized drop of the 3M Foam Pad Finishing polish. (This is really powerful stuff, you won't need more than this). Again, rub in circular motions. Do this for another 5-8 minutes. You will see how the shine really comes out. You can see in this pic how well the cutting gel did.
http://www.pghconsulting.net/detail/plastic4.jpg
When you're done, it should look like this...(you can see the stark difference)
http://www.pghconsulting.net/detail/final.jpg
And....
http://www.pghconsulting.net/detail/final2.jpg
This will work for most of the plastic on your car. The rubber pieces obviously won't come out like this, but no harm in running some cutting gel over them just to get rid of some of the oxidation.
Hope this helps some of you in your next car wash... :)
BlazerLT
04-06-2005, 05:10 PM
Do you apply a wax after the cut and polish?
rlith
04-06-2005, 05:55 PM
Nope..... That's bare plastic... Once it's polished you really don't need to worry about it for a year or 2...The plastic on my wife's truck still looks like the day I did it (last year)
BlazerLT
04-07-2005, 12:11 AM
wow, I am really impressed.
Looks like 10 mintes and they are back to new.
Yum!
DjEarth
04-07-2005, 01:22 AM
Thats awesome..thanks for the tip!
Google
Web AF
