98 v6 missfired4h8a1 04-04-2005, 11:01 AM about 130,000 miles on this car, with plug wires + plugs less than a year old. I was comming home the other night and noticed it was kinda shaking. It rapidly declined into a state of undriveability. Turns out, its missfiring on cyl. 4. I can feel the injectors pulse, new fuel filter, the plugs all look wet (w/ gas), and ive tested the coil and cam sensor like it shows in the book. The only thing I can think of thats left is the plug wires. Has anyone heard of a wire failing after just a year? Brian R. 04-04-2005, 01:36 PM Switch the wire with another of approximately the same length (cyl 3?) and see if the miss moves with the wire. If is doen't, it's not the wire. d4h8a1 04-05-2005, 09:48 AM It doesnt quite work like that, theres just three wires, the one side hooks up to a coil, and that coil drives both cylinders. The timing is done by computer through a cam position sensor. I went out and bought new wires yesterday, it still does the same stuff. I had to go to work, and while i was there my dad came home and started messing with it. He said there was a grinding noise like it threw a rod or something. The motor has plenty of clean oil. We just replaced the clutch last week, taking the engine out for a thrown rod... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
