maybe buying 1998 svt9000vtec 04-03-2005, 06:58 AM ok i found black svt 60k on it for 8G i never owned ford so dont know crap obout it im looking for good performance car to be tunned not alot but just for extra kick to it i have few options 1996 civic hatchback b18c1 gsr engine type r trans 3k on the new engine7500$ +rims and 1 inch lowerd 1998 svt 60k 8450$ and rims 1998 honda civic ex vtec body kit springs engine boltons and rims 49k 8500$ 1997 probe gts 40k 6800$ had 2 integras but seems they have been in papers for long time and they are sold what would u choose im looking for performance looks handling etc and i will be tunning it litle bit everythign except turbo maybe later when i said to my friends ford they said no there engines suck except mustang cobra is it tru? ppl say they dont last long and when u get to the higher milage like 100k its gona start having alot of engines problems what u think is it tru do they have weak engines? im looking for good stock performance and reability so that that it dont brakes after few months now i have 98 eclipse gst with few boltons its my second engine since i bought it yeah weak engine quality beyondloadedSE 04-03-2005, 02:38 PM $8450!!! thats outrageous! I wouldnt pay more than about $6000 for that svt. Just take a look on ebay and how cheap they are. The svt motors are fairly strong. Stock rods have taken up to 300 whp. Nobody has yet to break a set. Stock crank is good for 1200 whp. The 98-early 99 pistons have a weak ringland design and have shown failure under boost applications. The 2000s came with a revised ringland and are fine. For naturally aspirated motors, its not an issue. Some have experienced spun rod bearings due to oil starvation, so most people including myself run 6 quarts of oil instead of the recommended 5.5 qts. Only thing thats a weak link is the stock differential. Its glass. Lots of wheel hop on a hard launch is a quick way to shatter it. Theres quite a bit of aftermarket available for the contour. A lot of people just dont know about it, because they aren't members on contour.org which is where a lot of the products started. (i.e ArizonaDynoChip turbo kit, every carbon fiber hood, etc). People on CEG have well over 200K on their 2.5L and are still running strong. Mine had 80K, before I upgraded to a 3.0L and turbo kit and the only thing i ever replaced on it was the waterpump at 72K. Now thats not to say, some people didnt have problems, but thats true for every manufacturer. Somebody always gets stuck with a lemon. Tell your friends to do some research on the contour before they bash Ford. The 2.5L duratec they put in the contour came directly from a porsche motor. Porsche engine http://memimage.cardomain.net/member_images/11/web/503000-503999/503505_126_full.jpg Contour engine http://memimage.cardomain.net/member_images/11/web/503000-503999/503505_83_full.jpg I would definetely choose the svt. Just not that one, since its way too expensive. The svt contour platform handles awesome. Anyone that ever takes a ride in one is for sure impressed. As far as looks and uniqueness I again would have to go with the svt. Only 11,455 were made over its 3 year span. Jason43 04-03-2005, 03:36 PM Sounds like your friends don't have a clue. The 2.5 duratec is a top notch motor. The only real problems with it, as stated above, is the oil starvation issue. This can be avoided with not only running a little more oil, but also avoiding hard right hand turns under full throttle. I would also go with the SVT out of that list. Its quick, stops well and handles even better. 9000vtec 04-03-2005, 10:05 PM i was always a fan of svt they look hot even stock so do u think i should ask for maybe 6500$? see what he says now im just looking for a good deal and waiting for summer to come here in denver co to start buying beyondloadedSE tx for the help i knew svt had aftermarket parts buy just looking at it 9000vtec 04-04-2005, 02:33 PM what to look for in svt egine when buying common problems what are they ? wonna know what to look for when buying it what brakes in questions 1.what brakes easily 2.most commong problems found in svt 3what to look for when buying one tx for ur help beyondloadedSE 04-04-2005, 03:08 PM what to look for in svt egine when buying common problems what are they ? wonna know what to look for when buying it what brakes in questions 1.what brakes easily 2.most commong problems found in svt 3what to look for when buying one tx for ur help 1. plastic impellar waterpump. Just upgrade to revised metal impellar. Also the stock differential as i said earlier is very easy to break. 2. Third gear syncro grind. Others could grind too, but third gear is typically the most common. Id say a lot can be learned from the previous owner by how smoothly the trans shifts. If its been beat on, chances are, youll be able to tell when you drive it. Be sure to put 6 qts of oil in, since oil starvation has been known to spin a bearing on long right hand sweeping turns. 3. Missing jackcovers, curb rash along front fascia, if its a black svt inspect for small blotches of spiderwebbing paint. Theres been a few known occurances. Be sure to drive the car and inspect transmission epsecially. Theres more common problems that you can check over on contour.org in the FAQ's. 9000vtec 04-04-2005, 03:19 PM how mutch would be to replace differential for stronger one that wont brake so easily? next weak im gonna go and see the car test it and offer 6000$ if he wants if not well il just keep looking Jason43 04-04-2005, 03:44 PM IIRC, LSD's go for around $600. The stock differential should hold up under normal driving conditions, but if you plan on drag racing it, the LSD is a must. Few other common problems off the top of my head: -late 99-00 models will at some point need a new fuel pump. Theres a screen on the bottom of the pump housing that gets clogged, causing the pump to burn up. -the sunroof gears have been known to melt in warmer locations. There was a person on contour.org who started a group buy for the gears. 9000vtec 04-05-2005, 02:50 PM i made mistake in svt price here is what it says in teh paper 1998 contour svt black 60k on new engines with warranty all papers and receipts will be shown to buyer *** *** **** phone number after market exhaust and new tires must sell got married 5800$ obo i copied this form auto trade i would offer 5000 and i dont race but i like to do it lil bit with my friends 600$ isnt bad for LSD at all i would stay on normal when when it brakes then i would raplace it beyondloadedSE 04-05-2005, 05:05 PM sounds like he spun a bearing from the description of the ad, since it lists a new engine. Should have just upgraded to a 3.0L, but im sure he paid the stealership about $5000 to put in a new svt engine with warranty. $5800 sounds pretty good to me. Btw, installing an lsd is a pretty labor intensive job. The engine must be lowered so the trans can be pulled. Expect to pay about $350 in labor if you already have the trans out of the car. Jason43 04-05-2005, 07:03 PM I've heard more than a few horror stories of dealerships replacing blown SVT motors with the standard 2.5. I'd check on that too. 9000vtec 04-06-2005, 04:32 AM yea sure will vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
