low oil pressure
stephenp
04-03-2005, 01:41 AM
how many psi of oil pressure should i have at idle, after warm up im below 5 on the digigage im normal but analog says 3 psi or so and cat 1000rpm i got 20 and by 4000 i get 60??
are these normal numbers an what can i do to overcome???
ExTrEmEDrIfT
04-03-2005, 03:31 AM
the digital dash is inaccurate alot usually you should have about 10psi for every 1,000 rpm
stephenp
04-03-2005, 07:19 PM
so other than idle im ok then hmm must be the bearings are starting to wear just not dead yet hmm
k3smostwanted
04-03-2005, 07:28 PM
or maybe your sensor isnt all that accurate which could be a huge possibility...
stephenp
04-03-2005, 07:42 PM
its an aftermarket gauge ? still think it is inaccurate i guess i dont know why not
k3smostwanted
04-03-2005, 08:51 PM
oh...well. who knows???
ExTrEmEDrIfT
04-03-2005, 08:53 PM
yah the oil pressure sending unit is natorious for going bad in the z31's...
stephenp
04-03-2005, 11:29 PM
mechanicel 1/8" copper line fed oil pressure gauge
reads approx 2 3 psi after warm up at approx 700 rpm all aftermarket equip no sender completly mechanicl i fear i probably have low oil pressure
then again i tried to use some redline oil after being a religus castrol syntec user
hmm are there that many detergents or something allthough it sounds good and smooth and hell even after idling for 10 min with the said 3 psi it sounds perfect i touch the throttle the pressure builds???? i guess well see she sounds great for what she is though lol
stephenp
04-04-2005, 10:41 PM
well i think i cured that problem i just switched back to my origanal opil and its all good
approx 12 psi at idle after warmed and reved and idled and reved blah blah blah
ExTrEmEDrIfT
04-04-2005, 11:48 PM
well sounds good to hear tahts all it was was an easy fix ..
stephenp
04-05-2005, 07:33 AM
yeah and i had peopl try and shun me away from it ??? said no dont spend that kinda money on it
i was like it she is not an it (lol) she is my wife would you buy your wife a cubic zerconuim (i would but only to spring for good oil for my baby lol)
