94' Accord Atenna broken...HELP!!
RomainDeaMarchi
03-31-2005, 06:03 PM
Hey guys, my 1994 Accord LX 4dr's attena is broken. I look in the hole and it looks like it just got broken off somehow. Im not too sure if the motor is dead. Can anyone help me on how to replace it and check and see if the motor is broken or not..i dont want to replace the motor and attena when the attena was just snapped off. Thanks guys
mpumas
03-31-2005, 08:05 PM
The antenna motor runs when you turn the radio on or off whether the antenna goes up or not. If you don't hear anything, the motor may not be running due to a blown fuse or a burned out motor. The unit is removable and can be disassembled. If the motor is running when you turn the radio on, remove the holding nut on the outside of the car and then turn on the radio. The antenna should be expelled. A new mast can be purchased and fed down the hole with the teeth facing to the rear. When the teeth engage, turn off the radio and the mast should be drawn down into the tube. When the motor stops, push the antenna down by hand and reinstall the holding nut. You may have to cycle the motor a couple of times, pushing down on the antenna if it doesn't go all the way down when the radio is off.
Igovert500
03-31-2005, 09:26 PM
RomainDeaMarchi
04-08-2005, 10:01 AM
Im looking at a new atenna mast and motor on Ebay for $30 without tax/shipping buy it now. Is this a good deal or can i find cheaper? Any help here? Thanks
mpumas
04-08-2005, 10:45 AM
That is really cheap. I would question the quality of the offer and the reliability of the seller. New masts without motor go for about $50.
Igovert500
04-08-2005, 12:43 PM
When mine broke, I got a new mast at Pepboys or something for alot cheaper than $50...it was a universal, but it worked fine. You could probably get one that cheap from someone parting out a car on here, or from a local junkyard.
RomainDeaMarchi
04-08-2005, 03:38 PM
Its 29.99 with 12$ shipping..thinking this is a good deal i guess. How do i remove the old antenna on the outside of the car? Does it unscrew or pop off?
Igovert500
04-09-2005, 11:18 AM
Did you see the link I posted....check it out...at the bottom of each page is the link to the next page...each page has step by step instructions on how to do this.
AccordCodger
04-09-2005, 12:43 PM
Igor, it tells me www.hondapitstop.com is not found.
RomainDeaMarchi
04-09-2005, 02:30 PM
Yeah that link doesnt work
Igovert500
04-11-2005, 12:28 PM
that is odd...it works fine for me. Are you clicking on the link or copy pasting it into your browser...as it seems AF's programming code likes to abbreviate links when they are posted. But I just double checked it again, and it works fine for me...
AccordCodger
04-11-2005, 02:41 PM
Must've been bad at the time 2 of us tried - it's OK now.
