'93 Camry LE AT: R & D indicator lampsmikehd 03-31-2005, 12:40 AM My sis got a new-to-her '93 Camry recently. The R & D indicator lamps for the transmission gear do not light up on the dash (between the tach and speedo). Likely the bulbs are burned out. To remove the instrument cluster, it appears that there are two screws in the upper portion of the cluster, and some screws behind the HVAC control knobs. Are there any other tricks? Does anyone have the lamp part numbers that I'll need? I'm planning on replacing them all since I'll have it out. thanks, Mike mikehd 04-02-2005, 07:13 PM Got the bulbs from the dealer. Now, I see two screws in the upper part of the instrument panel, plus two more hidden by the radio fascia. Any others? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
