AC is on and offczm400r 03-30-2005, 07:35 PM I have a 99' Blazer that has been great. Today in Chicago it peaked out over 70 Degrees and when I tried the A/C nothing but outside air temp. I popped the hood and the compressor would start and spin for a few seconds and then stop. It kept doing this over and over not staying on long enough for cold air. Is this common or do I need to get to the dealer for a look. BlazerLT 03-30-2005, 07:41 PM Your refirgerant and your A/C oil is low. Do not use the AC anymore until you get it recharged or you will be replacing your compressor. czm400r 03-30-2005, 07:57 PM Thank you, Is this normal? for a car this old? BlazerLT 03-30-2005, 08:01 PM Thank you, Is this normal? for a car this old? They all have to be topped up from time to time. If you want to stop the AC compressor from turning on, remove the electrical connector from the top of it for now. That way you will be able to use the defrost seting without hurting the AC system. chris15706 03-31-2005, 12:29 AM I had a similar problem with my 2000 s-10. Started acting weird just like yours then it stopped all together. Turned out the low pressure switch went bad. It will cut off when your coolant is getting low. Check the coolant level and if that is ok check out that switch. BlazerLT 03-31-2005, 12:33 AM I had a similar problem with my 2000 s-10. Started acting weird just like yours then it stopped all together. Turned out the low pressure switch went bad. It will cut off when your coolant is getting low. Check the coolant level and if that is ok check out that switch. If the comperssor is cycling on and off, the refrigerant is low. BlazerLT 03-31-2005, 12:34 AM did you replace the ignition module on the distributor? chris15706 03-31-2005, 12:36 AM Thats probly why my switch burnt out. It was expensive too. Had to get it from the dealer $60 because none of the auto stores had it in stock for the stupid flex fuel! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
