it died.....anyone know if its fixable
Google
Web AF
white90rex
03-25-2005, 08:12 PM
So my car died....heres how it happened......it go towed and as soon as i got it back i was leaving the tow yard and hit a deep puddle.....it didnt look that deep.....and while in this puddle my car stopped and shut off .........i have cold air intake and im pretty sure that my entire filter was covered by water, so im sure the motor has water in it. it wont start or even turn over for that matter. i dont want to send it to the grave yard ......i you know please help!!
civickiller
03-25-2005, 08:19 PM
first thing would be to change the oil and let all the water in the oil pan come out
DTangent
03-25-2005, 08:35 PM
My suggestion, start looking for a new motor. j/k dude. Take off the valve cover and plugs. Stick in a tube through the spark plug hole, and try siphoning off any excess water (if it hasnt drained already). Then do as said above. Take off oil pan, change oil and clean out oil pan. Then, cross your fingers as you take off the pan and hope that you don't see a bent rod or something. Low rpms = possible survival of engine if it hydroed. High rpms = you're screwed. The engine had to relieve somehow, usually meaning a bent rod or hole through something else, piston or block.
03-25-2005, 10:05 PM
Wow that is some luck.
I hope your engine isn't shot. My friend had a '98 Civic with a CAI that went down into the air dam, and he hit a puddle, sucked water up through the intake, and bam. Dead engine.
I hope this didn't happen to you.
johnb16a2
03-25-2005, 10:15 PM
Also make sure your valve timing is correct. It's possible the belt may have jumped when everything came to a sudden stop. GL
Ones&zeros
03-26-2005, 04:31 AM
get u'r self a bypass valve after that.
white90rex
05-04-2005, 02:01 AM
thanks for all the help guys but the motor is gone and the car got broken into in the tow yard and now everything is gone. but thanks fr the help
Exempt
05-04-2005, 02:47 AM
Damn bro, that sucks... U have some bad luck... Hope things start turning around for u tho...
johnb16a2
05-04-2005, 08:08 AM
That's awful! Does the tow yard bear any responsibility for the break in?
crxlvr
05-04-2005, 08:37 AM
i doubt that, most yards never take responsibilty for break ins and shit. thats some tough luck man, hope everything gets better for you.
SiZ
05-04-2005, 05:09 PM
ITS STILL FIXABLE!
Now you have a great project. :p
Sucks to your asmar, but replacement motors are all over the place for reasonable prices, and same with whatever was taken out of the inside.
Sorry bout your luck though.
Google
Web AF
