how to install clear corners?
Google
Web AF
sinaloa350
03-24-2005, 12:14 AM
i just ordered a buddy of mine some clear corner lights for his cavalier, but he says he doesnt know how to install them, i dont know anything about cavaliers really and dont know either, can someone help me out?
01Cavy
03-24-2005, 12:30 AM
I have an 01 cavy, and my corners are connected to the headlight on the side. There is a little tab that you use a screwdriver or something to pry it off the headlight and it is a piece of cake from there.
sinaloa350
03-24-2005, 05:48 PM
anyone got any pics?
sinaloa350
03-25-2005, 10:44 PM
ok so should we just stick a screwdriver between the headlight and corner light and just pop it out?
01Cavy
03-25-2005, 11:58 PM
Sorry been working alot so havent had time to take pictures...and probably won't till next week. I'll try to get you some pictures of the clip.
sinaloa350
03-26-2005, 12:00 AM
is it the same with most models? his is a 95
01Cavy
03-26-2005, 12:03 AM
I'm almost sure it is. I'll take pictures of mine in the morning and have them up tomorrow after 9pm cst and you can compare.
sinaloa350
03-26-2005, 09:33 PM
alright man sounds great
01Cavy
03-26-2005, 11:42 PM
Sorry I couldn't get them today...its been a long day. I'm making a note to do it in the morning.
sinaloa350
03-28-2005, 10:05 PM
whenever you can get em its cool
01Cavy
03-28-2005, 11:49 PM
I took the picture, but it won't come out too well. Its too dark, and flash doesn't help...makes it worse. I will have to transfer it from one pc to another to get it up for you. It doens't exactly show the clip, but I can lable it so you can find the location of it. Hopefully it isn't much different in your model than in mine. I'll definitely have it up sometime tomorrow night. Been trying to get it up sooner, but not exactly easy between school and two jobs. Sorry for taking so long.
01Cavy
03-30-2005, 11:47 PM
Sorry it took so long.
http://files.team-nz.com/sigs/clear.jpg
I couldnt get a good picture of it so I couldn't actuall show the clip, but where the line ends on the right is where the clip is on my 01. Once you see it you can tell how to get it off. No screws or anything else to take out. Putting it back in is easy. I used a screw driver to get mine off.
Like i said thats how it works on my 01...hopefully its the same for your model.
sinaloa350
03-31-2005, 12:02 AM
so you stick the screw driver on the headlight side or the other side?
01Cavy
03-31-2005, 06:08 PM
The clip is in that little hole that the line ends at. I don't remember which way the clip goes to losen it. I want to say it goes away from the headlight towards the corner light.
Heres what jbody.org says to do:
Installing clear corner lenses on a 95+ J-body
Raise hood.
With a pair of pliers, remove the black fasteners securing the black shield in the front. There should be 6 - 7 of them. (To remove them, take pliers and raise the head of the fastener. Then pull the whole thing out.)
Remove black shield.
Remove the top bolts securing the head lamp assembly (they should both be located on top). Two per head lamp.
Remove head lamp gently without pulling too hard on the wires. It is not necessary to remove the light bulb.
Unplug the light from the side signal light.
Remove the three bolts that secure the side signal light.
Remove signal light and install clear corner lights. Change bulb if desired.
Reinstall head lamps and shield.
014drcavalier
04-06-2005, 02:31 PM
Just a hint you dont have to remove the headlamp or the black cover to get to the corner lens.. But that is just for 00-02.. Its a lil bit different for the 95-99.. sorry i cant tell you how to do though
sinaloa350
04-06-2005, 06:38 PM
yea i got the lights and we installed the lights on his car, thanks guys for the help!
shawnwilliams
04-07-2005, 02:28 PM
www.importmodifications.com has pictures to show you how to do it.
Google
Web AF
