98 Tahoe Engine Problems
Google
Web AF
khtrombone
03-23-2005, 08:21 PM
My 98 Tahoe with 155,000 miles started idling rough and using oil last month. Prior to then, it ran very good. Although it does not smoke on start-up or while running, the tail pipe is coated with black soot. It uses a quart of oil every 250 miles! I've read the following codes in the last two weeks: P0420(cat eff below threshold bank 1), P0174 (system too lean bank 2), P0171(system too lean bank 1) and P0305 (Cyl 5 misfire). Compression is 175 - 180 on all cyliners except # 6 is 155 - 160. Seven plugs were dry, but looked blacker than I would have expected for 30K miles (GM OEM Platium). Plug in cyl 3 was very oily. I changed all plugs which improved idling somewhat, but cyl 3 was really bad again in 500 miles. I've had the Tahoe on the road for 500 miles round-trips in last week and it ran great - plently of power and good gas mileage (16 or so). I've changed the oil every 3,000 in this one and it's never been hot. I changed the intake gasket last year to repair a coolant leak. The PCV was changed three months ago. Also, I had a noisey lifter on the passenger side so I ran a quart of marvel mystery oil through a couple of oil changes ago and that eliminated the clicking. Since I've got low compression in #6 where the noise was coming from, I think I may have a valve problem on that side, but I don't know what would be causing the bad fouling of plug number 3 and excessive oil useage unless I've got a ring failure. Could that be the problem even with 180 psig compression in that cyliner? May be too much info here, but any help would be appreciated. I'm afraid I may be headed for the reman engine store!
amac209
03-23-2005, 09:49 PM
before resorting to a reman engine i would replace the valve seals. if the oil control rings are stuck/broken/worn out you will still have compression but oil will seep through.
Pakeboy2
03-30-2005, 07:55 PM
We had just about the same problems...once the dealer changed out the catylac? converters everything went back to normal. Good luck.
SpitAndDirt
03-31-2005, 01:42 PM
I agree with the valve seal replacement suggestion. I did them on my 96 Z71 5.7L at 155,000 and now I don't use but 1qt over a 6,000 mile interval. Before I would use a quart or more every 3,000 miles. By the way, do you only use your truck for short trips consistently? You may have a lot of sludge built up in your valve cover areas and in the oil pan. Short trips are hell on a vehicle, make sure your giving enough time for the engine to warm up and boil off any condensation in the oil which leads to sludge formation. -Chris
tykrz
05-14-2005, 01:47 PM
Blue smoke on start up after vehicle has sat for a while = worn valve seals or guides.
Blue smoke on engine decleration when you rev the engine up and down = worn piston rings or cylinders
On a high miler engine your further ahead to spend the money towards a rebuild instead of patching it up and spending it again down the road.
Google
Web AF
