Rear Defog.....Sp3cops70 03-23-2005, 08:26 AM The rear defog don't work......the fuse is good and the connections in the back are connected properly. And the lines in the rear window are not broken from what i can tell.... Any Ideas?? Sp3cops70 03-25-2005, 10:26 AM ?????????????? jimmytroanoke 03-25-2005, 11:52 AM ?????????????? Did you check for voltage at the connections in the back? Trace the circuit back from there if none. Is the light staying on when you push the button. I am sure there is a relay in the circuit somewhere. Probably controlled by a body control module somewhere. You will need access to a schematic to troubleshoot this one. If you do have voltage at the connections in the back the problem has to be in the glass. Good luck! Sp3cops70 03-25-2005, 04:37 PM thanks........ 94sportsedan 03-26-2005, 02:58 AM Your relay may be bad. Whne you trun on your rear defogger can you here your relay click on? Also with a mulitmeter U should be able to measure 12volts across form one side to the other. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
