91 GP Turn Signal Switch R&Rgeojr 03-21-2005, 10:36 PM How do I remove steering wheel on 91 GP with redundant radio controls in steering wheel? Vehicle has tilt s/w and cruise on collum. I need to replace turn signal switch. Chazman 03-22-2005, 02:04 PM The stereo controls are held in by two clips, you should be able to pry the complete module out with a small slot screw driver. From there you just need a standard steering wheel puller. geojr 03-27-2005, 01:29 PM That worked really slick after the car sat in the sun long enough to warm it up inside. Thank You very much. $80 for the switch and a little labor is better than the $385 I was quoted!!!! Chazman 03-27-2005, 03:21 PM No problem, glad to help. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
