rims
Google
Web AF
smoovrider
03-21-2005, 02:12 PM
hey whats the deepiest off set we can put on our cars. cuz i got mine droped on air bags and i wanna put 19 on them.
smoovrider
03-22-2005, 06:14 PM
no one knows
carnutcass
03-23-2005, 09:02 AM
Have you called tirerack or any wheel dealer? They might be able to answer the question.
I would think that another factor you should consider, besides offset, is wheel width. My aftermarket wheels are the factory offset but because they are 8" wide I have to be careful which tires I buy because it used to scrape. I went from 245/50/17 to 225/55/17 and it no longer scrapes.
jimmytroanoke
03-23-2005, 09:47 AM
Probably hard to say without actually trying some on the vehicle. The stores always have fitment books but they are for stock suspension, and don't cover modified / lowered vehicles. The books also tend to err on the conservative side because small interference that may be acceptable to one is very unacceptable to another. And tire dealers don't like to give refunds because once a vehicle leaves their lot with 2k worth of tires and wheels they are USED and worth less than half. :2cents:
smoovrider
03-23-2005, 10:08 AM
yea tru. but i was lookin to buy some online like 225/40/18 in the front wit 18 x 7.5 - Offset: +35, or 18 x 7.5 - Offset: +48. they got different offset does thats mean anything? also 19 x 8 - offset: +40 in that back wit a 225/40/19
jimmytroanoke
03-23-2005, 10:24 AM
With your modification situation I would recommend strongly against going the online route unless you can talk to someone else with the same car and mods and duplicate their setup. If you by them online and put them on your car they are YOURS even if they make the car undriveable. Find a reputable local shop that is willing to work with your wants and needs and make it work for you. That is worth an exra couple hundred bucks.
Offsets determine how the tires sit on the car - how far they protrude etc. If your offsets are different front to rear you can't rotate your tires.
smoovrider
03-25-2005, 02:29 PM
oh i c i didnt know that. but c if i have 18 in the front and 19 in the back i wont be rotatin them anyways but yea ill keep that in mind tho. thanks
vamc
03-30-2005, 01:40 AM
I think you you try to put 19's on it, it will scrape the inside of your wheel well.also just a side note, keep in mind that 19's are about 10lb more then stock 16's. if you care about weight and preformence, keep this in mind.
smoovrider
03-31-2005, 12:38 PM
well since the 19 will be in the back i can cut the top of the wheel well so not much gonna scrap. but thanks
Google
Web AF
