no heat
Google
Web AF
fishmonster13
03-20-2005, 07:15 PM
my 96 v6 rodeo has no heat , i've installed a new thermostat have tried flushing the whole cooling system , the lines to and from the heating coil are hot , water pump is good ,i checked it when i changed the timing belt. any ideas ,do i just not flush it out well enough ?
amigo-2k
03-20-2005, 07:37 PM
the rad is probably plugged.
try searching here, that has been a couple of recent posts.
fishmonster13
03-20-2005, 08:15 PM
i flushed the radiator seems like it flows thru good
fishmonster13
03-20-2005, 08:16 PM
i flushed the radiator seems like it flows thru good the temp gauge reads pretty low
fishmonster13
03-22-2005, 09:33 PM
i figured it out , the blend door is stuck in the closed position due a broken pin from the heater control
Google
Web AF
