rodeo 2001 fog light next step
Google
Web AF
phil73
03-20-2005, 07:14 PM
Hello I tryed to install my fog lights, everything is perfect but I wanted to use a regular switch instead of OEM (I bought lights only...w/o the switch)
I tried to make it work but I'm not able to make it. Does anyonr knows how the cable is 'configured'
1 : unknown ??
2: 'negative' pole of the relay
3: 12V switch +engine
4: 12 V switched
5 : ground ??
wich wires should I put on the fog light switch ??? Unless I buy a OEM switch...
Thanks for any update
Philippe
megavolt121
03-21-2005, 02:48 AM
Why not buy a switch? St. Charles isuzu charges like 8-10 bucks for it if i remember correctly.
rodeo02
03-21-2005, 04:02 AM
I don't know the factory pinout, don't have a schematic handy. The OEM setup only allows the fogs to be used when the low beam headlights are on. There is a way to jumper that however, so the fogs can be used independantly. Do you have a relay plugged into the 'fog light' socket in the under hood power distribution box? Rodeo's that didn't come with fogs wont have a relay installed.
G/luck
Joel
phil73
03-21-2005, 09:51 AM
I check and it 40 $ Canadian, so I'll go with OEM .... my first info were 60-70... at 40$ I won't work two hours to find the wires and do connections
thanks
Philippe
spishack
04-06-2005, 04:17 PM
I bought new factory fog lights for my 2001 Rodeo that did not originally come with them. It apears that I need an additional bracket or some such. Does anyone have any more information on this?
Any and all help is greatly appreciated.
Thanks,
Mike
amigo-2k
04-06-2005, 04:21 PM
where did you buy it from? Did you get the kit?
spishack
04-06-2005, 04:26 PM
No, no kit was bought. Just the lights. I plan to buy an original switch as well though!
I can't remember where I bought them, somewhere on the internet but they are factory lights.
spishack
04-06-2005, 09:31 PM
So I guess I do need brackets, could anyone direct me to a good source?
amigo-2k
04-06-2005, 10:28 PM
salvage yard?
or maybe contact St. Charles isuzu?
spishack
04-07-2005, 12:10 AM
Thanks, I was hoping to be able to order them online though!
I really appreciate the help.
marcre
04-07-2005, 12:19 AM
Call St. Charles isuzu the number can be found in amigo2k FAQ link at the bottom of his post. You will get a good price from St Charles.
Marc
rodeo02
04-07-2005, 07:29 AM
Thanks,
Mike
I'll see if I can dig up the bracket part# from the kit I got a year or two ago... I'm thinking It will be difficult to buy JUST the OEM bracket, but you never know! Definately will be a dealer only item.
G/luck
Joel
spishack
04-11-2005, 04:31 PM
Thanks, any and all help is greatly appreciated.
spishack
04-12-2005, 04:32 PM
I ordered the brackets today from the local Isuzu dealership. Only $12.50 each!
phil73
04-13-2005, 09:50 AM
everything work perfetly.... Like everybody i had some problem with the bumper... I had to remove it , intall the lamps then replace the bumper..
Google
Web AF
