What are symptoms of intake leak or problem
Google
Web AF
crx1989
03-20-2005, 04:54 PM
I have a 98 GT with a miss on cylinder 2. Replaced wires, plugs, modules, injector and plenum. Love the car, just want problem to go away.
adblink182
03-20-2005, 06:33 PM
is the cylinder getting spark?
or you might not be getting any compression in the cylinder either, either your compression rings are gone, or the there is an issue with one of the valves
crx1989
03-20-2005, 07:09 PM
As far as I can tell it is running fine while I am driving, this only happens when I'm sitting at Idle.
adblink182
03-20-2005, 08:26 PM
how do you know you have a misfire on cylinder 2?
crx1989
03-20-2005, 08:42 PM
I plugged my little codereader into the diagnostic port and that is what it told me.
adblink182
03-21-2005, 12:41 AM
ok again check for spark (and check the gap of the spark too)
then make sure you have compression in the cylinder
3 required things to get an engine to run:
1) fuel
2) compression
3) spark
crx1989
03-22-2005, 10:14 AM
The spark is fine and the gap is good. Everything points to a vacuum leak but I can't be sure. I just want to explore all options befor having to disassemble the whole intake.
jimmytroanoke
03-22-2005, 10:56 AM
To check for vacuum leak spray carb cleaner around suspect areas while car is idling. when you spray the leak the idle will change dramatically.
Google
Web AF
