dhp pcmshooterc5 03-20-2005, 02:35 PM Hello Im thinking of buying a DHP Pcm for my 99 GTP. It has 93000 miles on it, CAI, Smaller 3.4 pulley, Tb spacer, and two heat range colder plugs TR6's. Will i be able to just swap out the DHP pcm for my stock and not have to worry about check engine lights and what not? I have heard of the case learn procedure when buying a new pcm and im not real sure what that is. Please let me know thanks. carnutcass 03-20-2005, 06:43 PM The PCM should work great with the mods you have. Might want to do a little exhaust work in the future. You will need a case learn. Any dealership that has a Tech II can do this. If your car is covered under a warranty you may not wantto have it done at the dealershipwhere you bought the car. It takes like two minutes to complete. shooterc5 03-20-2005, 06:52 PM OK thanks alot. If you dont mind would you be able to explain to me exactly what a case learn is and what it does? Im afraid im gonna go to the dealership and they are going to look at me and say wtf are you talking about. kustomkid54 03-20-2005, 07:15 PM OK thanks alot. If you dont mind would you be able to explain to me exactly what a case learn is and what it does? Im afraid im gonna go to the dealership and they are going to look at me and say wtf are you talking about. Here you go; (Post #4) Need to take it into a shop that can do a CKP Variation Learn/case learn. Any time one of these has been replaced CKP sensor Front cover or bracket holding the crankshaft position sensor Target wheel (reluctor) Crankshaft Engine block Engine assembly PCM http://www.seattleautomotive.com/ckpdoc.htm 97-2003 Engine CASE learn procedure:For DHP 1. Turn the key to on position 2. Turn Tech II on 3. Select the Diagnostics Menu 4. Select Car Information (Year, Make, Engine, Etc.) (Make sure they enter 1998 as the year.) (Also you will be asked what type of product line/type. It is a single letter code. Which corresponds to the first letter in your VIN) 5. Select Special Functions. 6. Select Variable Crankcase Learn Procedure. 7. Follow On Screen Directions. The Crankcase Learn Procedure is going to ask the Technician to do the following: 1. Put E-brake On. 2. Make sure car is in neutral or park. 3. Turn engine on 4. Rev Car to Rev Limiter (car will hit limiter at 3,000 RPM) 5. Wait about 5 seconds. 6. Rev Car to Rev Limiter (The car will this time hits about 5,500 to 6,000 RPM) 7. Wait about 5 seconds. 8. Car is done. kustomkid54 03-20-2005, 07:17 PM Here's another (samething); Print out the instructions and take it to the dealer or a shop that has a Tech II or IIRC even a good Snap On scaner will preform the crank position relearn.Tell them you need to have this service done and not to FLASH the PCM. 97-2003 Engine CASE learn procedure:For DHP 1. Turn the key to on position 2. Turn Tech II on 3. Select the Diagnostics Menu 4. Select Car Information (Year, Make, Engine, Etc.) (Make sure they enter 1998 as the year.) (Also you will be asked what type of product line/type. It is a single letter code. Which corresponds to the first letter in your VIN) 5. Select Special Functions. 6. Select Variable Crankcase Learn Procedure. 7. Follow On Screen Directions. The Crankcase Learn Procedure is going to ask the Technician to do the following: 1. Put E-brake On. 2. Make sure car is in neutral or park. 3. Turn engine on 4. Rev Car to Rev Limiter (car will hit limiter at 3,000 RPM) 5. Wait about 5 seconds. 6. Rev Car to Rev Limiter (The car will this time hits about 5,500 to 6,000 RPM) 7. Wait about 5 seconds. 8. Car is done. kustomkid54 03-20-2005, 07:18 PM Oh, the new Snap-on will do it also. shooterc5 03-20-2005, 07:33 PM thanks alot guys vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
