How to get to AT fluid fill plug?RodeoDaddy 03-19-2005, 04:08 PM OK.. I've done something stupid and nothing I'm really proud of... Draining my AT fluid in my 4x4 '97 Rodeo. Now, being a computer geek (not a car mechanic), I'm good at research and now know what to do to refill the fluids. But, does anyone have any info on how to actually GET to the fill plug as it seems a little out of sight high up in the vehicle? Tips or step-by-steps are all welcome. Please help. Thanks! Canucklehead 03-19-2005, 04:39 PM Not that I have an Auto Tranny but Haynes says that you fill it "through the overfill screw opening until it just starts to run out of the opening." rodeo02 03-19-2005, 11:33 PM Try a search. There is tons of detailed info on this. The fill/level check plug is just like the drain plug you pulled. It's just a few inches over, facing downward recessed into the rear corner of the large transmission pan. You have to pump ATF up into the fill port with a hand pump or the likes. Don't drive low on ATF or you will cook your 4L30E in no time. G/luck Joel RodeoDaddy 03-19-2005, 11:37 PM Thanks, Joel. That's exactly what I needed to know. RodeoDaddy 03-29-2005, 01:24 AM Welp... Got it done. Not too much trouble. Used the Garden Sprayer method to fill 'er up. Had to find a length of 3/8" hose to thread on to the sprayer nozzle in order to get it up high enough inside. Made sure I shfted through all gears after initil fill, stuck it in neutral then topped it off. After running it around for a while, I double checked the lvels and it seemed it was still full, as fluid sputtered out of the fill hole while running. Plugged 'er back up and all seems well. So far it hasn't burned up on me. Again, thanks for all the great help given to me and what I was able to find here. rodeo02 03-29-2005, 07:38 AM Good to hear you got it done! What I did that helped quite a bit is, made a 'hook' out of a piece of 3/8" copper tubing. Clamp the hose to the tubing & route the hook thru the fill hole so it stays in place nicely, and pump away! Fairly mess free, but I'd still like to slap the engineering marvels that eliminated the ATF dipstick :uhoh: ! G/luck Joel marcre 03-29-2005, 03:27 PM Fairly mess free, but I'd still like to slap the engineering marvels that eliminated the ATF dipstick :uhoh: ! G/luck Joel Agreed, the engineers made it so many people can't or wont do their tranny flush. Insteed they will pay to have it done. I did not feel comfortable enough to do mine so I had it done. surferfletch 03-29-2005, 11:00 PM Before I figured it out, I had to have mine towed. DUH! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
