dash lightsVinceH 03-18-2005, 05:11 PM Hey everyone, I recently helped a friend install a new cd player in his 99 rodeo and since then his dash lights do not work, fuses are all ok, any thoughts......? Canucklehead 03-18-2005, 09:05 PM Check the dimmer switch, maybe it is turned down all the way or perhaps there's a broken connection, jarice 04-07-2005, 02:08 PM I am having the same problem, did you figure out how to get the lights to work? amigo-2k 04-07-2005, 04:14 PM pull the dimmer switch and see if it is still connected. jarice 04-07-2005, 05:38 PM I have installed a new dimmer swithch with no change, any other ideas? bighops2000 04-11-2005, 01:21 PM you havent connected the orange or orange/white wire properly. they are wire into the dash lightsw disconnect the wires and chance the fuse under the steering coloumn vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
