Creeking in front end
Google
Web AF
crazyinkc
03-17-2005, 08:06 AM
I have a creeking in the front end of my 04 sedan. I was just wondering if anyone else has had a problem with the front end yet. It sounds like a stabilizer bushing.
hayesbcajh
03-18-2005, 08:21 AM
I get a wierd scraping sound when I hit a bump that causes the front end to dip. Sort of like when the plastic piece undeneath would scrape if you came close to bottoming out. I can't imagine it's bottoming out because it does it on relatively small bumps. I've been too busy lately to bring it in.
crazyinkc
03-18-2005, 10:21 AM
That sounds like what I am hearing also. I looked at it last night and it does sound like the swaybar. I have not got it up on ramps yet but it sounds like the bushings mounting the swaybar to the frame are dry. I seems to be getting worse. I will get it in the air tomorrow and see what I can find. I do not think it will be hard to fix so I would rather do it my self rather than have the dealer screw it up like they usually do. I will keep you posted on what I find and what the fix was.
crazyinkc
03-21-2005, 04:17 PM
It seems the creeking was coming from the vertical mounts on the rear of the lower A arm. I pulled the bolt out, cleaned it up, lubed with white lithium grease, and reinstalled. Drives like new again. i hope this is a perment fix. I will keep you posted.
hayesbcajh
04-07-2005, 09:48 AM
My creeking stopped when the temperature got above the 30s. Guess I'll get it checked out next winter.
XKHX
05-13-2005, 12:19 AM
hi
we have an aveo LS 2004 model hatch
we also have this creaking noise..we purchased in february'04 and it is still there. we have gone to the dealer time after time after time. first they said the struts were cracked and leaking..so they replaced those. we're now in the shop for what was told to us to be a strut mount that was binding. they've fixed that and the noise was still there. so now they are ordering a control arm for the steering..and they think that might do it.
basically we have had so many problems with our aveo
this issue has been ongoing for a year
also to add to it our neutral safety switch was adjusted, and then replaced because we kept getting locked in Park position on our AT
the abs brake module went out
we've had the keyless entry system fuse blow 5 times in a year
our rear driver lock doesnt open on occasion when using RKE
and we have a chirping/rattle in our dash, they attempted to fix this and failed, and in the process damaged our glove box
i just feel the overall craftmanship on this vehicle is below standards
ive inquired about buy back.. have been told by many service advisors and salesmen that it is an option, to contact GM customer service.. we've gone all the way to executive offices of Chevrolet, and nothing is going to be done for us. just keep going back with the problems until they are resolved.
anyone have any insight on this??!?!?!
im desperate for resources at this point
beckyvr
02-22-2006, 01:46 PM
I also have an 04 Aveo 5 with major creaks and groans from the front suspension - dealer has done everything GM will allow them to do and stiill the noises. Phoned GM "Customer Service(????)" and was told that I must keep taking it back until it is fixed no matter how inconvenient.....
Yesterday a factory technician drove it and said that the creaking and plastic scraping sound occurs on all 04 models and that is that - paying customer does no count in their eyes
Dealer was totally embarassed having to pass this onto me
My first and definitely the last GM piece of crap I will ever buy
Anyboidy have any suggestions?
crazyinkc
02-22-2006, 01:54 PM
The creaking is in the vertical mounts at the rear of the lower A-arm. The dealers think I am an idiot but they have yet to fix it. I heard the 06's have an "updated front suspension". My sister and brother-in-law have two 05's that do the same thing. I have sprayed WD-40 on the bushings to prove it was them and they just looked at me and laughed. I am waiting until it is out of warranty and pulling the lower A-arms and filling the void areas (which is the problem due to them flexing and rubbing rubber to rubber) with urethane sealant which is what they are made of anyway. I wonder why GM is loosing so much market share. Hum?
tune1552
02-24-2006, 02:41 AM
Where do you live and how much do you charge? LOL.......
crazyinkc
03-01-2006, 09:25 AM
I am in Overland Park Kansas. I will be doing my A-arms in a month or so and I will try and document what I did and if it worked.
Shadow Z
03-03-2006, 02:11 AM
i will be doing this tomorrow, now that i know what that noise is.
I've had that since i launched it off a ramp, lol. but this may help.
ill try to document my experiences as well
tvent
03-18-2006, 11:08 PM
I've got this problem as well, sounds like its happening to a lot of cars. Just wanted to document it, hope others post their problems as well. The dealer just said it was a normal sound. Is there something specific that I can tell them to do to fix it? I guess I expected more quality out of this car, but it was cheap. Still I wish Chevy would mimic some of the qualities of Honda and Toyota.
XKHX
04-26-2006, 01:06 PM
your situation sounds like ours
we purchased my aveo 2/04 and we're still battling the same problem
but it seems to be getting worse. the noise is louder and scarier
it sounds like the whole car is going to crumble in the front end
do you notice any performance issues related? like increased wear on tires, alignment issues, or braking problems?
just wondering.
i love the aveo...but i sincerely believe mine is a pile of junk
i would give anything to get into a newer model... i should have known better than to buy the first year run of this
i could try a trade-in..but i bet then they will find the problem and knock a few thousand off the value with my luck
tune1552
04-26-2006, 03:58 PM
One major thing about this car, the trade in value.
I have talked with two dealerships about getting out of this car into a newer nicer different make of car, they wanted to give me just 5k for the Aveo. ITS AN 05 FOR GODS SAKE! The first chance I have to get out of this car Im gonna jump on it, this car has no resale at all.......I like the car, but dam!
phantomcobra
05-02-2006, 07:37 AM
Did someone actually expect a high resale value on a $10-15K car? EVERY car drops 25-40% the second you drive it off the lot. And a dealer will drop it lower than that so they can have a profit margin when they resell it. Lets say you buy a $12K car and it drops 40% the first minute. Your value is now $7,200. Take out a couple thousand for dealer profit in reselling (even if the car needed no repair, etc.) and you are down to $5,200 for a trade in.
If you want resale value, buy a 60s Mopar muscle car!
aveo54
08-06-2006, 11:32 PM
Have creaking/crunching noises primarily from the front-end, but also from the rear. Sounds like the entire front end is coming off. Dealer lubed the lower control arm bushings per the GM TSB, but it didn't help a bit.
Am resigned to replacing any/all bushings with better quality parts when they are finally available, as well as new aftermarket shocks and struts.
The steering and stability of my 04 sedan just keeps getting worse and worse. The car is always shifting side-to-side and you can feel movement from every breeze. I'm very disappointed with the suspension -- someone didn't do their homework!:mad:
hayesbcajh
09-14-2006, 10:20 AM
Had the creeking checked out at the dealer yesterday.
I don't have the paperwork yet as it's still an open case and we're waiting for parts.
Apparently there are 2 bulletins on the topic. First they loosened something on the control arms and re-torqued it. They reported that after the test drive the noise was still there. My drive home confirmed this. I guess the second one has them replace something. They ordered the parts and I'm scheduled to go back next wednesday.
Will post again after the next service.
ema
09-14-2006, 09:00 PM
Thanks for input everyone...I am still in the works...got rep to drive with me to hear creeking in my aveo after they tighten a bolt in the lower control arm to ball joint (if that sounds right). According to the boyfriend that work on cars all his life, this is unusual to happen without any damage done. Also that it would cause the tires to be out of line and wear tires improperly. They say it won't but I think I am going to address them in writing my concerns in case there is improper wear.
I am going to get them to lubricate the bolt at rear of the lower a-arm.
The whole idea was to have a new car was to get a break from self repairs. I am not impressed with the aveo. She still under warranty. god knows what to expect after that.
They also adjust headlights twice for me....screw fill out and light moved blinded everyone driving in front of me...The third time I am demanding it to be replaced. I'll let you know the results.:)
hayesbcajh
09-15-2006, 07:21 AM
To be honest, I'm not going to worry too much about the creeking. Mine has done it since new and now has 34k miles on it. My tires seem to be wearing normal and I don't notice any performance issues. No doubt a new car should not be making any noise whatsoever. But me personally, I can live with the annoyance if it turns out that after they replace parts the noise is still there. The only thing I am going to ask of the dealer is to put in writing that if this is the cause of a future repair they will cover it.
We'll see what happens next week.
hayesbcajh
09-29-2006, 07:40 PM
Got my car back tonight after the 3rd attempt and the noise seems to be gone. Apparently there were 2 different noises that the shop noticed. On 1st visit they re-torqued something to no avail. On the 2nd visit they changed the sway bar bushings and said they solved one of the noises. I'm not sure because the noise I brought it in for was still there...I never noticed a second noise. Could very well be since the noise I was concerned about was so loud. That or they ordered the wrong part and changed them anyway. When the sway bar bushings went on my chrysler minivan it gave a clunking sound not a squeaky sound. On the 3rd visit (today) they changed the right front lower control arm bushing. So far no noise. Even after I drove over the gutter into my driveway there was no noise and it was always the worst over this bump. I am optimistic that they have solved my problem. And just in time at 35,000 miles.
Piece_Ride_Driver
11-25-2006, 11:42 AM
2004 Aveo sedan, I have the same problems, creaking is especially louder in colder weather. Aveo sucks.
Google
Web AF
