High Water temp, Cold Air From Heaterreparadis 03-16-2005, 12:00 PM I have a 1992 Rodeo w/ V6, when I first start the car the engine will warm up to normal temperature. After a mile or so the gauge becomes very erratic. When the gauge is in the red cold air comes from the heater. I replaced the thermostat with one rated for 195 degrees but didn’t solve the problem. I also verified the fluid level in radiator and overflow. I didn’t find any questions that exactly matched my problem. Could this be caused by a defective radiator cap or pinhole in the hoses? Thank you in advance for your assistance. Robert Paradis amigo-2k 03-16-2005, 12:13 PM This is a common cause of an old plugged radiator. If you are still running the OEM rad, switch it out. http://www.automotiveforums.com/vbulletin/showthread.php?t=366151&highlight=radiator reparadis 03-16-2005, 01:08 PM Thanks for the quick response. I'll replace the radiator this weekend. steveb_92rodeo 03-17-2005, 08:45 AM Thanks for the quick response. I'll replace the radiator this weekend. Depending on the state of the tanks, you may be able to get the rad re-cored for a cheaper price than a new one. Personally, I wouldn't go that route, but it may be an option you want to look into. Steve vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
