Water pump replacementavmx 03-14-2005, 09:44 PM 97 xj w/4.0L Anything special I should be aware of before starting to replace the pump? I'm assuming it's the pump 'cause I see a leak at the pump just above the the lower hose (leaking from the weep hole??). How long should the whole replacement take?? bayouwolf 03-14-2005, 10:25 PM Nothing special...Just remember to tighten EVERYTHING once your finished...I forgot to tighten a bolt on the fan shroud and ended up nearly ruining the radiator in the process...took me about an hour with basic handtools...the pulley on the A/C compressor belt was a bit of a pain the old ass...other than that, just like any other water pump on a rear wheel drive... thinmints 03-15-2005, 11:51 AM 97 xj w/4.0L Anything special I should be aware of before starting to replace the pump? I'm assuming it's the pump 'cause I see a leak at the pump just above the the lower hose (leaking from the weep hole??). How long should the whole replacement take?? try this link http://jeepin.com/features/waterpump/page2.asp vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
