03 Fuel Filter
Google
Web AF
SHOWDOWN
03-14-2005, 06:18 PM
Can Somebody Tell Me Where The Fuel Filter Is Located On A 03 Trailblazer And If It's Easy To Do Yourself. ThankS
markbair
03-15-2005, 09:24 PM
Hi there...I have an '03 EXT, so it may be different, but mine was located on the driver side, pretty much abeam the drivers door. It is on the inside of the rail underneath, so you will need to get it in the air. (Jack up the truck, or use a lift) It is one of the easiest jobs I've done...takes 15 minutes tops. All you need is a phillips screwdriver, to loosen the bracket holding the filter in place, and the connectors that connect to the filter are "tool-less". Just squeeze them together and they come right off. Be ready for some fuel to spray if you don't release the pressure. (There is a fitting that looks like a tire guage that you could use right there to release the pressure, but it will still spray so watch your eyes)
It is very easy and you can surely do it yourself! I hope this helped!
SHOWDOWN
03-16-2005, 06:49 PM
Thanks I'll Give It A Try This Weekend
SHOWDOWN
03-20-2005, 02:33 PM
BUMP
markbair
03-20-2005, 02:40 PM
Why did you bump?? You still got questions??
Google
Web AF
