88 Fox rough idle when startedbacklit 03-13-2005, 03:01 AM Hi I own a 88 fox. When I start it when its cold, the engine runs really rough til its warmed up. Pretty close to stalling out if I dont give it some gas while idling. Once it's warm it runs great. Any idea of what this could be caused from? Thanks. arbie 03-14-2005, 05:37 PM hey i have the same problem with my 89 fox.. except when my car is warm it still idles poorly to the point of stalling. i was told i should speed up or turn up the idle is this right Ryu_biggie 04-02-2005, 03:23 AM u might have a bad cold start injecter. so u don't have the fuel u need when u start. change it i have no clue what that might cost. vwsmp 04-28-2005, 03:47 PM ive had the same problem ever since i had my vacuum hosing reworked. i always thought it was just a minor leak in the system. you might check along the length of the hose from the distributor to the fuel distributor. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
