4.0L not running right, sensors/computer??upx974 03-12-2005, 05:19 PM after filling up at the gas station, randomly my '88 cherokee 4.0L starts and runs for about 5 seconds and dies. fuel pump working, fuel filter clear. egr has been bypassed for some time but has never given me problems. after removing filter and draining lines, now runs for about 25 seconds and dies. possible fuel delivery problem, or sensor(s) or computer?? getting plenty of pressure at fuel rail. a lot of hesitation when it does run. any help would be appreciated. thanks scuba4321 03-12-2005, 05:44 PM are you getting a check engine light? Dale Aeppli 03-12-2005, 06:03 PM after filling up at the gas station, randomly my '88 cherokee 4.0L starts and runs for about 5 seconds and dies. fuel pump working, fuel filter clear. egr has been bypassed for some time but has never given me problems. after removing filter and draining lines, now runs for about 25 seconds and dies. possible fuel delivery problem, or sensor(s) or computer?? getting plenty of pressure at fuel rail. a lot of hesitation when it does run. any help would be appreciated. thanks ON THE DRIVERS SIDE INNER FENDER THERE IS A WHITE CERAMIC RESISTER BLOCK TRY PUTTING A JUMPER WIRE BETWEEN THE TERMINALS DALE upx974 03-12-2005, 06:05 PM nope, no check engine light. another note, after towing it home ~10 miles from gas station, it started and ran normal, drove it up and down road. shut it off and problem returned..dont know what to do.... Dale Aeppli 03-12-2005, 06:09 PM nope, no check engine light. another note, after towing it home ~10 miles from gas station, it started and ran normal, drove it up and down road. shut it off and problem returned..dont know what to do.... COULD BE THE CRANKSHAFT SENSOR IS GOING BAD DALE jeepman600@sbcglobal.net upx974 03-12-2005, 06:23 PM jumped wires, runs slightly better, prefers higher rpms. what does this mean? Dale Aeppli 03-12-2005, 08:16 PM jumped wires, runs slightly better, prefers higher rpms. what does this mean? Could be the resisier is weak. Try replacing it they;re not expensive $ 5-6 . dale vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
