tubeless tiresbillyboyb 03-12-2005, 10:35 AM can i put a tube in a tubeless tire to fix a slow leak thats i can't find no matter what???....thats cheaper than a NEW WHEEL OR TIRE..... :banghead: rallyaddict 03-12-2005, 04:18 PM I don't know the answer. What I do know is that you should use snoop or something of the like to locate the leak. I would not replace the tire nor would I use a tube. If the leak is in the tire, it can be patched. If it is at the bead, get it re-seated. If it is at the valve, get it replaced. If you have alloy rims it is very likely it is at the bead. You will not likely need a new tire. billyboyb 03-12-2005, 05:40 PM I don't know the answer. What I do know is that you should use snoop or something of the like to locate the leak. I would not replace the tire nor would I use a tube. If the leak is in the tire, it can be patched. If it is at the bead, get it re-seated. If it is at the valve, get it replaced. If you have alloy rims it is very likely it is at the bead. You will not likely need a new tire. Thanks....good advice... :) noshun 03-13-2005, 01:51 AM no don't use a tube!!! Blowout likelyhood about tripled! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
