Cleaning out my Motor...
Google
Web AF
Hellbilly
03-11-2005, 09:45 AM
My Blazer is comming out of the shop today..
I had new V Seals and the Heads cleaned....I told my mech to just fill it back up with cheep oil cause i wanted to clean out the whole thing..
What product would youll recomend to flush the whole motor out? (Something that can be got in a autoparts store...I gota trip comming tommorow and I dont have time to order)
and whats the best procedure?
Rick Norwood
03-11-2005, 01:10 PM
See my thread on Loud Lifter Knock for the exact procedure, however, to answer your question, I used the "GUNK" brand. Cost about $2.50 USD for approx. 35 ounce bottle. The bottle says 5 minute Flush but I would leave it in 30 minutes AT IDLE ONLY.
DO NOT REV THE ENGINE WHILE THIS STUFF IS IN THERE. :grinno:
BlazerLT
03-11-2005, 03:06 PM
I will be test piloting AutoRX for my truck.
Check it out here:
http://www.auto-rx.com
This stuff has been proven to work miracles and I need one for my sludged up 4.3L.
s10blazerman4x4
03-11-2005, 03:30 PM
gunk works fine makes it good and black
blazes9395
03-11-2005, 03:39 PM
GM has a good cleaner. Its called I think engine crankcase cleaner. I have had extremely good results with it. SAme idea as all the rest, pour it in, run the engine at idle for a certain amount of time, and drain it. Its very strong, and can be picked up at a GM dealer parts outlet.
Rick Norwood
03-11-2005, 03:59 PM
Here is what I did:
Buy the "Gunk" brand engine cleaner and the cheapest 5W-30 oil on the shelf. Drain the oil and install a new (Cheap) filter and add the new cheap oil along with the Gunk flush being carefull not to overfill the system. Start and run the engine 30 minutes AT IDLE. Drain the the system again and dump in a 1/2 qt. of castrol GTX 5W-30 while the drain plug is out to flush any remaining cheap oil/flush out. Install the oil pan drain plug, then fill the system with Castrol 5W-30 and a brand new AC-Delco Filter. You should not have any more lifter noise.
Bodaggit
03-11-2005, 06:28 PM
So cleaning one out like that doesn't hurt the bearings in the engine or anything? I've always been a little hesitant about cleaning out my engine. I have a little over 80,000 on mine right now, and I don't think it would heart it to be cleaned out. I get a little lifter noise sometimes after starting it when it's been sitting for a while, and I always use Valvoline 5w-30 motor oil. Maybe it's just timr for a cleaning.
BlazerLT
03-11-2005, 08:02 PM
Do you use an orange Fram filter?
Bodaggit
03-12-2005, 02:12 AM
no, I usually get a pure one.
BlazerLT
03-12-2005, 02:33 AM
I would do an Auto-RX cleaning cycle.
Product can be found here:
http://www.auto-rx.com/
This stuff is amazing.
mumser101
03-12-2005, 07:43 AM
Auto-Rx is a safe alternative to solvent-based engine flushes. The 5 minute solvent flush may break off chunks of sludge and clog oil passages. Auto-Rx is a slow process, taking 1500 miles to dissolve layer by layer of sludge.
Take a look at a test by a skeptical user who thought Auto-Rx was snake oil. Go to www.rms13.com.
There is also a discount coupon code floating around: ARXOF.
roofcleaningtampa
07-22-2008, 12:23 PM
Cleaning is important.
I cleaned mine too.
In my situation, a big difference was made by the cleaning.
ZL1power69
07-24-2008, 10:55 AM
This thread is over 3 years old. Please refrain from posting in old threads.
Google
Web AF
