will rims off of a 92 vette fit my 84 vette
Google
Web AF
pinkchicken
03-25-2002, 04:02 PM
will rims off of a 92 vette fit my 84. all four rims are 17"x9.5"
flylwsi
04-13-2002, 04:21 PM
it's the same bolt pattern. wheels off of a 60's vette will fit either of those years too...
you just need to double check on backspacing, and how much space you need...
your bolt pattern is 5x4 3/4
Big Jim
04-29-2002, 05:43 AM
Hi Fly,
I just went through the whole deal myself so I can tell you what they tell me and what I figured on my own.
I have an '87 C4. I wanted to put 17x9.5" rims on the car to replace the 16x9.5" stockers. I was told that a C4 with 17" wheels ('88 and newer) had a different backspacing than cars with 16" wheels. I was told I'd need to purchase spacers ($225 at Eckler's) to use 17" 'vette wheels (or aftermarket wheels with the same spacing) on my '87. My wheels have something like a 54mm back spacing and the wheels I wanted had 38mm backspacing. I may be off on the figures a little but you get the idea.
Anyway, I decided to purchase the wheels and try them without the recommended spacer. I put 275/17's tires in front (standard size for a 17" wheel) and 315/17's in the rear. Well, the 275's did look a little too far in on the front but the 315's looked perfect on the rear.
My conclusion is, if I had bought and installed the recommended spacers, I couldn't run 315/35-17 tires because they would stick out too far to look right. I'm just going to replace the 275's I have in front with 315's and then it will look totally awesome!. I'm glad I didn't listen to the "experts" and figured this out for myself. I hope you can use this info the way I did. I see no difference in our situations as you also want to put 17" wheels off of a new C4 to replace your 16" ones on your '84.
Now to the topic page so I can ask my question.
BIG JIM
Google
Web AF
