87 toyota 4x4 22r rod bearings
modification_inc
03-09-2005, 08:41 PM
I Just Started To Get A Knock Out Of My 22r At 148,435miles.is It Possible To Just Put A Set Of Rod Bearings In It?
sassee
03-11-2005, 11:36 PM
Well......I don't exactly remember if anything is in the way of the oil pan, but i'm pretty sure it's possible. BUT, if you have bearings worn enough to cause a noticable knock, you're probably gonna have to have the crank turned and get some over-size bearings! OR the crank bearings could be the culprit! Either way, the crank's gotta come out! Sorry, that's not what you wanted to hear was it?
modification_inc
03-21-2005, 10:04 AM
Ok Heres The Problem. I Have Put New Rod Bearings And Main Bearings,oil Pump,timing Kit And Gaskets In And I Still Have The Knock.the Oil Pan Had No Pieces In It And I Inspected The Rockers And There Fine. The Wrist Pins Are Good Also. Any Ideas????
modification_inc
03-21-2005, 10:13 AM
Also The Sound Seems To Be Coming From The Timing Cover Crank Area
sassee
03-21-2005, 08:57 PM
Did you pull engine or replace bearings with engine in truck? Did you have crank turned and get oversize bearings? Now, you say "knock" Is this a steady noise in sync with the engine RPM's??? Are you sure you replaced thrust washers in number 3 main cap? Did you check crank shaft end play? what about rod end play?
I hate to say it but if you have a "knock", it's probably still bearing related or crank or rod had lot of wear and clearances are excessive!
