refinish wheels
mrfirebird
03-07-2005, 12:16 PM
anyone here refinished there aluminum wheels?
if so ,what did you use to take off old clear coating and how did they come out.
swalt
03-07-2005, 02:23 PM
Use a high quality paint stripper. You can pick some stuff up at Home Depot (circa 1841) or something like that. It goes on as a gel, eats the paint and then you rinse it off. Be ready for some elbow work and I would suggest having a compressor with a die grinder and stripping discs to remove (grind down) the factory machining lines and help with the initial polishing. I did the rims on my wife's grand am and they looked amazing. A lot of grinding, sanding and wet sanding and polishing though. I did the faces that were easily accessible and the spots that were on the inside I painted with aluminum rim paint and then clear coated.
http://files.automotiveforums.com/gallery/watermark.php?file=/500/116754grandamresized.jpg
BlazerLT
03-07-2005, 03:08 PM
I would use google, lots of refinishing tips.
mrfirebird
03-07-2005, 08:52 PM
looks great swalt, i figure there is alot of polishing,thanks for the reply
