97 Eurovan Door Panel Removal
Google
Web AF
jimd2p
03-06-2005, 03:53 AM
Need some help here as I am beating my head. I have a 97 Eurovan, camper edition. On both doors, a portion of the lock cylinder fell off, so the cylinder came out with the key. On the driver door, I was able to remove the handle and retrieve the part. On the passenger side, I wasn't as lucky. I need to remove the panel to fish out the part. I removed the screw at the inner portion of the door (at the front fender if the door were closed), removed the cover on the door handle and removed the three screws holding it on. From here I am lost. I can not find any other screws. I can see the panel looks like it must lift up and off. This has power windows and locks.
Thanks in advance for any advice.
harley01564
03-28-2005, 10:33 AM
I have a 2000 Eurovan and I had to pop off the speaker grill, then remove the speaker and unplug it. Then remove the 3 screws that hold the speaker mount in. Then lift the panle straight up. This is of course after you have already removed the screws that you mentioned in you post. I hope this helps.
Google
Web AF
