Starts when it wantsdualcarb88 03-23-2002, 09:03 AM A friend has a 91 Accord LX 5- speed with 217.000 miles on it.. The problem is it runs when it wants to ??:confused: Checked the igniter...OK, checked TDC...OK, no codes on the computer, Injectors are pulsing, dropped the tank and changed the pump... no change, when it does decide to run, the motor stumbles at low RPM:confused: :mad: Any help would be nice, Thanks twizzaut 03-23-2002, 12:36 PM u might have to get a new ignition put in 93speed 03-23-2002, 04:39 PM Did you check the distributor cap? That happened to my 93 Accord. Try spraying some wire dry stuff on it. Mine only did it when it was wet (obveously). twizzaut 03-24-2002, 02:35 PM does it cut off when ur driving? if so it will be the ignition dualcarb88 03-24-2002, 04:36 PM Once it starts it will run as long as you want it to vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
