96 Jetta GLS taillights always on?
Google
Web AF
maxim26
02-28-2005, 10:34 PM
hello, on a 96 Jetta GLS, are the L & R tail lights supposed to be on as part of the daytime running lights feature? I have an electrical problem which leaves my tialights & center rear stoplight on all the time, that I am trying to diagnose. It would be useful to know if the L& R tail lights are part of the DTR lights thing or not.
Thanks for your replies
boschmann
03-01-2005, 02:20 PM
No they are not. It could be a grounding issue in the trunk or tail light housing area or an issue with the headlight switch.
nicoleos
03-02-2005, 04:21 PM
I have the same problem, but when i brake, they light brighter. My third taillight is always on, too.
nicoleos
03-02-2005, 05:49 PM
Will that do anything to my battery or damage anything?
boschmann
03-02-2005, 07:48 PM
Nicoleos, you probably have a bad ground connection back there.
nicoleos
03-03-2005, 01:21 PM
Boschmann, when my car is off, and i step on the brake, the cluster light and the ac/ defroster light lights also. What does that tell me?
boschmann
03-04-2005, 06:18 PM
Have you noticed any relationship to moving the ignition switch?
nicoleos
03-07-2005, 01:44 PM
When i step on the brake, it lights the dash and makes a clicking sound, except when i have the ignition on auxiliary mode. Then, the lights come on automatically, but not clicking sound!?!
boschmann
03-09-2005, 06:46 PM
I still think there's a problem with the wiring in the rear. Possibly a bulb twisted in improperly.
mike1989
11-23-2005, 11:27 PM
check your fuses.
mike1989
11-29-2005, 10:41 PM
if you get a clicking sound your relays might be the problem. you should check that out
Google
Web AF
